Pick the linked status
On 03/03/2017 at 02:07, xxxxxxxx wrote:
Hi guys.
An input in a node can be linked or not. When linked, a dot is added within the circle of this input as below :
In a python node, I want to check if this entry is linked or not.
Which way is the best to reach this goal ?
Thanks in advance for your help.
On 03/03/2017 at 04:53, xxxxxxxx wrote:
Problem solved. 🙂
Solution here : https://gist.github.com/NiklasRosenstein/7126526
On 06/03/2017 at 02:59, xxxxxxxx wrote:
Hi Condor,
welcome to the Plugin Café forums 🙂
Glad you were able to answer your question yourself and thanks for providing a link to the final solution.
