On 28/02/2017 at 14:49, xxxxxxxx wrote:
Don't know if it's a bug or not (that take me a while to figured this but) Here is a log from the console..
Arnoldcylinderlight.CheckType(5102) True Arnoldcylinderlight <c4d.BaseObject object called 'Arnold cylinder_light/Arnold Light' with ID 1030424 at 0x000001179A329C10>
Why CheckType return True? Using GetType working fine
if Arnoldcylinderlight.GetType() != 5102:
while not CheckType don't.
if not Arnoldcylinderlight.CheckType(5102) :
On 01/03/2017 at 02:27, xxxxxxxx wrote:
This is not a bug. The documentation states that C4DAtom.CheckType() checks if the atom is an instance of a base type. And it should be true that an Arnold Light is an instance of c4d.Olight base type ( 5102 ). Note C4DAtom.IsInstanceOf() does exactly the same as C4DAtom.CheckType() but its name is better.
On 01/03/2017 at 02:35, xxxxxxxx wrote:
Thanks you for the informations for acheving that I was sure we must use C4DAtom.GetClassification() Then for me the only solution is by doing if Arnoldcylinderlight.GetType() != 5102:
It's jsut curiosity since I get everything working ^^.
