How to update a variable in a dialog?
On 11/02/2017 at 13:53, xxxxxxxx wrote:
Hello there,
How to update a variable in a dialog "CreateLayout(self)".
in the script below I want to passing the value from the path field or the self.DIRECTORY to the variable "dirs".import c4d, re, os from c4d import gui class Dialog(c4d.gui.GeDialog) : SELECT_DIR = 40 def CreateLayout(self) : self.GroupBegin(0,c4d.BFH_SCALEFIT,3,0,""); self.AddStaticText(0, c4d.BFH_RIGHT, 0, 0, "Path :", c4d.BORDER_NONE) **self.AddEditText(1, c4d.BFH_SCALEFIT, 250, 15)** **#Path to pass** self.AddButton(self.SELECT_DIR, flags=c4d.BFH_RIGHT,inith=15, name="...") self.GroupEnd() self.AddComboBox(1000, c4d.BFH_SCALEFIT, 0, 15) self.AddChild(1000,0,"Folders :&i" + str(c4d.RESOURCEIMAGE_OPENED) + "&" ) self.AddChild(1000,0,"") **dirs = os.listdir(os.path.join( self.GetString(1))) # Passing the path value or the self.DIRECTORY here** ** # or** **: # dirs = os.listdir(os.path.join(** ** ** ** **self.DIRECTORY****** )) ** id = 2000 for plugin_name in dirs: self.AddChild(1000,id,plugin_name) id += 1 return True def UpdateDlg(self, id) : self.SetString(1,self.DIRECTORY) return True def Command(self, id, msg) : if id == self.SELECT_DIR: **self.DIRECTORY** = c4d.storage.LoadDialog(flags=c4d.FILESELECT_DIRECTORY) self.UpdateDlg(self.GetLong(1000)) return True def CoreMessage(self, id, msg) : if id==c4d.EVMSG_CHANGE: self.UpdateDlg(self.GetBool(self.DIRECTORY)) return True def main() : global Dialog Dialog = Dialog() Dialog.Open(c4d.DLG_TYPE_MODAL, xpos=700, ypos= 200, defaultw=516, defaulth=10) return True if __name__=='__main__': main()
I want to obtain this result:
Thanks
On 13/02/2017 at 01:49, xxxxxxxx wrote:
To dynamically update the ComboBox children list, just call self.AddChild() in Command() with the sub-directories returned by os.listdir().
The ComboBox is updated automatically because this doesn't change the layout of the dialog.
On 13/02/2017 at 04:51, xxxxxxxx wrote:
The ComboBox is updated automatically because this doesn't change the layout of the dialog.Hi,
Sorry, I wasn't clear on your response, please can you give me a small example?
Thanks.
Thanks.
Simply move your loop with self.AddChild() from CreateLayout() to Command() and the if for the directory selection. CreateLayout() doesn't get called every time a command or an interaction in the dialog happens.
On 13/02/2017 at 05:33, xxxxxxxx wrote:
def Command(self, id, msg) : dirs = os.listdir(os.path.join(self.GetString(1))) id = 2000 for plugin_name in dirs: self.AddChild(1000,id,plugin_name) id += 1
I tried this but nothing happen.
