[SOLVED]Can i Isolate Each Object?
On 27/01/2017 at 04:56, xxxxxxxx wrote:
hi guys,
hope y'all are great are doing great,So is it possible to isolate each object?
because c4d.documents.IsolateObjects(doc, T_obj) dont work when using like thisdoc = c4d.documents.GetActiveDocument() if doc == None: return False # Get Models form the Object Manager objs = doc.GetActiveObjects(1) if not objs: gui.MessageDialog("Select objects") return False for E in objs: doctemp = c4d.documents.IsolateObjects(doc, E) if doctemp == None: return False
but it ask for all objects which is objs.
so it look this :doctemp = c4d.documents.IsolateObjects(doc, objs)
and that what it likes but it do all of them , what i want is each object when execute.
so its like each object go in it own folder.plz help and i hope this was understandable to y'all.
Thanks,
Ashton
On 27/01/2017 at 06:13, xxxxxxxx wrote:
The new doc created with isolateObject is not inserted in the list of user doc.
Here an exemple of something I wrote in 5 min and 3months ago(that mean he could have some errors and its not well documented...).import c4d import os def main() : current_dir = doc.GetDocumentPath() buffer_path = None list_obj = doc.GetActiveObjects(c4d.GETACTIVEOBJECTFLAGS_0) if not list_obj: return new_doc = c4d.documents.IsolateObjects(doc, list_obj) c4d.documents.InsertBaseDocument(new_doc) if not current_dir: return buffer_path = os.path.join(current_dir,"file_buffer.c4d") c4d.documents.SaveDocument(new_doc, buffer_path, c4d.SAVEDOCUMENTFLAGS_DONTADDTORECENTLIST, c4d.FORMAT_C4DEXPORT) path = c4d.storage.LoadDialog(flags = c4d.FILESELECT_DIRECTORY) if not path: return filename = c4d.gui.InputDialog("Nom du dossier", "Dossier") if not filename: return assets = list() missingAssets = list() path = str(os.path.join(path,filename)) c4d.documents.SaveProject(new_doc, c4d.SAVEPROJECT_SCENEFILE | c4d.SAVEPROJECT_ASSETS | c4d.SAVEPROJECT_PROGRESSALLOWED | c4d.SAVEPROJECT_DIALOGSALLOWED | c4d.SAVEPROJECT_SHOWMISSINGASSETDIALOG, path, assets, missingAssets) if buffer_path: os.remove(buffer_path) if missingAssets: gui.MessageDialog("Missing Asset\n" + str(missingAssets)) #c4d.documents.KillDocument(new_doc) if __name__=='__main__': main()
On 27/01/2017 at 14:41, xxxxxxxx wrote:
Hi gr4ph0s
I like what your code is doing but its really like this:
if I have 4 cubes in the scene , and select them I want them to export each object separately as a export file like .dae
so i would have:
Cube.dae
Cube1.dae
Cube2.dae
Cube3.dae
in the folder I send it too.problem is i need each object to Isolate it self and continue the process.
On 28/01/2017 at 13:44, xxxxxxxx wrote:
thanks I got it.
I was missing this :get_E = E.GetName() fobj = doc.SearchObject(get_E) sobj = doc.SetActiveObject(fobj) get = doc.GetSelection() new_doc = c4d.documents.IsolateObjects(doc, get)
cheers
