Call button of BaseObject
On 26/01/2017 at 12:01, xxxxxxxx wrote:
Cinema 4D Version: R15
Platform: Windows ;
Hello,I am translating a Python script to C++, but I don't find how to perform the CallButton.
Python :
defMaillage = c4d.BaseObject(1024543) # Ocameshdeformer inex = c4d.InExcludeData() inex.InsertObject(peau, 1) defMaillage[c4d.ID_CA_MESH_DEFORMER_OBJECT_CAGE_INCLUDE] = inex defMaillage[c4d.ID_CA_MESH_DEFORMER_OBJECT_EXTERNAL] = c4d.ID_CA_MESH_DEFORMER_OBJECT_EXTERNAL_SURFACE doc.InsertObject(peau) defMaillage.InsertUnder(soi.obj) c4d.CallButton(defMaillage, c4d.ID_CA_MESH_DEFORMER_OBJECT_INITIAL)
C++ :
BaseObject* defMaillage = BaseObject::Alloc(1024543); //Ocameshdeformer BaseContainer* bc = defMaillage->GetDataInstance(); InExcludeData* inex = (InExcludeData* )bc->GetCustomDataType(ID_CA_MESH_DEFORMER_OBJECT_CAGE_INCLUDE, CUSTOMDATATYPE_INEXCLUDE_LIST); inex->InsertObject(_peau, 1); bc->SetInt32(ID_CA_MESH_DEFORMER_OBJECT_EXTERNAL, ID_CA_MESH_DEFORMER_OBJECT_EXTERNAL_SURFACE); _doc->InsertObject(_peau, nullptr, nullptr); defMaillage->InsertUnder(_obj); // CallButton ?
How can we simulate the click to the button action ?
By the way, the InExcludeData* inex is null here, I don't know why. : /
Thanks,
César
On 27/01/2017 at 01:19, xxxxxxxx wrote:
These posts could help:
https://plugincafe.maxon.net/topic/5687/5723_copy-from-irr-command
https://plugincafe.maxon.net/topic/7229/8287_programatically-freeze-all
https://plugincafe.maxon.net/topic/7229/8287_programatically-freeze-all-Pim
On 27/01/2017 at 07:11, xxxxxxxx wrote:
Hi César,
basically CallButton() in Python is just a convenience function wrapping some messages.
In most cases it will be enough to send a MSG_DESCRIPTION_COMMAND, like so:
DescriptionCommand dc; dc.id = DescID(DescLevel(id, DTYPE_BUTTON, op->GetType())); op->Message(MSG_DESCRIPTION_COMMAND, (void* )&dc);
In special cases (and it doesn't hurt to do it all the time, so does CallButton internally as well) a few more messages are needed:
DescriptionCheckUpdate dcu; dcu.doc = GetActiveDocument(); // NOTE: this depends, in NodeData derived plugins NEVER use GetActiveDocument(), in CommandData it's fine though dcu.descid = &dc.id; dcu.drawflags = 0; op->Message(MSG_DESCRIPTION_CHECKUPDATE, (void* )&dcu); op->Message(MSG_DESCRIPTION_USERINTERACTION_END); op->Message(MSG_TOOL_RESTART);
For the nullptr question: For some reason the InExcludeList of the Mesh Deformer (opposed to other objects I checked) is uninitialized.
So if you get a nullptr, you need to initialize it with default data first. Like so:if (!inex) { // Init InExcludeList with default data bc->SetData(ID_CA_MESH_DEFORMER_OBJECT_CAGE_INCLUDE, GeData(CUSTOMDATATYPE_INEXCLUDE_LIST, DEFAULTVALUE)); inex = (InExcludeData* )bc->GetCustomDataType(ID_CA_MESH_DEFORMER_OBJECT_CAGE_INCLUDE, CUSTOMDATATYPE_INEXCLUDE_LIST); } if (!inex) return false; // something went wrong, error // go on with your code here...
On 27/01/2017 at 10:27, xxxxxxxx wrote:
Thanks, it works very well !
