Enable / Disable button
On 31/12/2016 at 21:05, xxxxxxxx wrote:
Hello there,
How can I disable a button if the selected object not an editable object, the example below do that but not exactly what I want. In the example below if I select anther object without closing the dialog, nothing is happening.
I want to autoupdate the enabling or disabling of the button without closing and reopening the dialog if I select anther object
I hope that is clear.
import c4d, os from c4d import gui, documents, plugins PLUGIN_ID = 1234567 class MyDLG( c4d.gui.GeDialog) : def UpdateDlg(self, id) : doc = documents.GetActiveDocument() op = doc.GetActiveObjects(False)[0] **if op.GetType() != 5100 : self.Enable(1000,False)** def CreateLayout(self) : self.SetTitle("Texel Bake") self.AddButton(1000, c4d.BFH_SCALEFIT, 0, 13, "Button") return True def InitValues(self) : self.UpdateDlg(self.GetBool(1000)) return True class MyPlugin(c4d.plugins.CommandData) : def Execute(self, doc) : global RunDLG RunDLG = MyDLG() RunDLG.Open(dlgtype=c4d.DLG_TYPE_ASYNC, defaultw=0, defaulth=0) c4d.EventAdd() return True if __name__ == "__main__": help = "" icon = c4d.bitmaps.BaseBitmap() dir, file = os.path.split(__file__) fn = os.path.join(dir, "res", "icon.tif") icon.InitWith(fn) plugins.RegisterCommandPlugin(PLUGIN_ID, "My Plugin", 0, icon, help, MyPlugin())
Thanks.
On 01/01/2017 at 08:10, xxxxxxxx wrote:
Use the timer function of gedialog
import c4d, os from c4d import gui, documents, plugins PLUGIN_ID = 1234567 class MyDLG( c4d.gui.GeDialog) : def CreateLayout(self) : self.SetTimer(250) self.SetTitle("Texel Bake") self.AddButton(1000, c4d.BFH_SCALEFIT, 0, 13, "Button") return True def InitValues(self) : self.UpdateDlg(self.GetBool(1000)) return True def UpdateDlg(self, id) : doc = documents.GetActiveDocument() op = doc.GetActiveObjects(False) if not op: self.Enable(1000,False) return if op[0].GetType() != 5100 : self.Enable(1000,False) else: self.Enable(1000,True) def Timer(self, msg) : self.UpdateDlg(self.GetBool(1000)) a = MyDLG() a.Open(c4d.DLG_TYPE_ASYNC)
Moreover another tips never do op = doc.GetActiveObjects(False)[0]
Check if op is not None before ;)
On 02/01/2017 at 03:18, xxxxxxxx wrote:
Using a timer works but I think catching EVMSG_CHANGE is a better solution:
class MyDLG( c4d.gui.GeDialog) : ... def CoreMessage(self, id, msg) : if id==c4d.EVMSG_CHANGE: self.UpdateDlg(self.GetBool(1000)) return True
Also calling c4d.EventAdd() inside the Execute() of the command plugin is unnecessary.
On 02/01/2017 at 07:57, xxxxxxxx wrote:
Thank you guys for your replies.
