On 09/12/2016 at 05:16, xxxxxxxx wrote:
User Information: Cinema 4D Version: 16 Platform: Windows ; Language(s) : C++ ;
--------- I want to update the userdata gradient. Getting the information is ok, but updating and wrting back the knots is not ok. Cinema 4d hangs!
obj->GetParameter(dscID, d, DESCFLAGS_GET_0); //Get the info of this specific UD item and store the values in "d" Gradient* gd = (Gradient* )d.GetCustomDataType(CUSTOMDATATYPE_GRADIENT); Int32 kcnt = UDfloorGradientKnots.GetCount(); //knots previous stored gd->FlushKnots(); for (i=0; i<kcnt; i++) { eFKnot = UDfloorGradientKnots[i]; knot.col = eFKnot.col; knot.pos = eFKnot.pos; gd->SetKnot(i, knot); } d.SetCustomDataType(CUSTOMDATATYPE_GRADIENT, *gd); obj->SetParameter(dscID, d, DESCFLAGS_SET_0); //here cinema hangs! EventAdd();
On 09/12/2016 at 14:45, xxxxxxxx wrote:
Since we are heading into the weekend and the support guys will be gone for a couple of days. I'll post my solution for you.
//This code changes the color of the knots in a UserData based gradient gizmo Bool MyPlugin::Execute(BaseDocument *doc) { BaseObject *obj = doc->GetActiveObject(); if (!obj) return false; //Get the object's master UD container that holds all the UserData entries DynamicDescription *dd = obj->GetDynamicDescription(); if (!dd) return FALSE; //Get the gradient gizmo from the UD manager GeData d; Int32 gizmoID = 1; //The ID# assigned to the UD entry in the UD manager DescID udEntry(DescLevel(ID_USERDATA, DTYPE_SUBCONTAINER, 0), DescLevel(gizmoID)); obj->GetParameter(udEntry, d, DESCFLAGS_GET_0); //For safety reasons we should check that the gizmo is a gradient type gizmo if (d.GetType() != CUSTOMDATATYPE_GRADIENT) { GePrint("Wrong Data type"); return false; } Gradient *gd = (Gradient* )d.GetCustomDataType(CUSTOMDATATYPE_GRADIENT); //Get the number of knots Int32 kcnt = gd->GetKnotCount(); //GePrint(String::IntToString(kcnt)); //We need to delete(flush) all of the knots to change them (yes..this is stupid...But that's how it's changed) //So we first need to grab and store the current knots data in a list maxon::BaseArray<GradientKnot> knots; for(int i=0; i<kcnt; i++) { GradientKnot knot = gd->GetKnot(i); Vector col = knot.col; Float32 pos = knot.pos; knots.Append(knot); } //Delete the existing knots gd->FlushKnots(); //Use the stored knot values to re-create them with a different color value for(int i=0; i < knots.GetCount(); i++) { if(i==0) knots[i].col = Vector(1,0,0); //Set the first knot color to red else knots[i].col = Vector(0, 1, 0); //Set the rest of the knot's colors the green gd->InsertKnot(knots[i]); gd->SetKnot(i, knots[i]); } //Update the object to reflect the changes obj->SetParameter(udEntry, d, DESCFLAGS_SET_0); EventAdd(); return true; }
On 10/12/2016 at 07:22, xxxxxxxx wrote:
Hi ScottA,
Thanks again for your support. I did remove "gd->SetKnot(i, knot);", I do not think it is needed and indeed it also works without it.
-Pim
