UV relax
  • On 04/12/2016 at 06:54, xxxxxxxx wrote:
    Cinema 4D Version:   R18
    Platform:   Windows  ;
    As the CallUVCommand isn't functional within the Python API, I have been playing around with the C++ SDK.
    I am trying to perform a relaxation of the polygons defined in the BaseSelect bsPolys , given a set of edges specified in BaseSelect bsEdges. However, I haven't found any documentation, nor example as how to set the BaseSelect into the BaseContainer being passed to CallUVCommand.
    Could someone explain, or point me to some explanation how to go about this?
    Thanks
      TempUVHandle* handle = GetActiveUVSet(doc, GETACTIVEUVSET_ALL);
      if (handle)
          BaseSelect* bsPolys;
          BaseSelect* bsEdges;
          BaseContainer bc;
          bc.SetBool(RELAXUV_CUT_EDGESEL, true);
          bc. ??? (RELAXUV_EDGESEL_POINTER, ??? bsEdges); //     <-----------
          bc.SetBool(RELAXUV_KEEP_NEIGHBORS, false);
          bc.SetBool(RELAXUV_KEEP_BORDER, false);
          bc.SetInt32(RELAXUV_MODE, RELAXUV_MODE_LSCM);
          CallUVCommand(
              handle->GetPoint(),
              handle->GetPointCount(),
              handle->GetPoly(),
              handle->GetPolyCount(),
              handle->GetUVW(),
              handle->GetPolySel(),
              handle->GetUVPointSel(),
              handle->GetBaseObject(),
              Muvpolygons,
              UVCOMMAND_RELAX,
              bc);
          handle->SetUVWFromTextureView(handle->GetUVW(), false, false, false);
          FreeActiveUVSet(handle);
  • On 04/12/2016 at 10:59, xxxxxxxx wrote:
    You need to use SetVoid() to use the active edges pointer.
    Here's an example written for R13
        PolygonObject *pObj = (PolygonObject* )doc->GetActiveObject();
      if (!(pObj && (pObj->GetType() == Opolygon))) return false;
      BaseSelect *EdgeS = pObj->GetEdgeS();
      TempUVHandle *handle = GetActiveUVSet(doc, GETACTIVEUVSET_ALL);
      if (handle)
          BaseContainer bc;
          bc.SetVoid(RELAXUV_EDGESEL_POINTER, EdgeS); //<---Use the currently selected edges when cutting the UVs
          bc.SetLong(RELAXUV_MODE, RELAXUV_MODE_LSCM);
          CallUVCommand(
              handle->GetPoint(),
              handle->GetPoly(),
              handle->GetUVW(),
              Muvpolygons,
              UVCOMMAND_RELAX,
              bc);
          //handle->SetUVWFromTextureView(handle->GetUVW(), false, false, false); //R17 function
          handle->SetUVW(handle->GetUVW()); //R13 function
  • On 04/12/2016 at 12:07, xxxxxxxx wrote:
    Thanks Scott.
    I looked into trying SetVoid, but got mislead as Visual Studio reported a mismatch in my code ... which turns out to be a typo.
    Your example works as expected. Thanks again.
