On 21/11/2016 at 12:31, xxxxxxxx wrote:
User Information: Cinema 4D Version: R18 Platform: Windows ; Language(s) : C++ ;
--------- Hello.
I want to create an ObjectData plugin that will represent a Light source in my render engine. There are 2 things that come in my mind but I'm not sure which is possible.
Override (somehow) the Olight object and hide the unwanted parameters. Also, add as parameters anything else that I need.
Create an ObjectData plugin and manually draw in the viewport the lines defined in Spot, Omni e.t.c.
Is there any example that I could use as reference ?
Thank you for your time.
On 22/11/2016 at 02:09, xxxxxxxx wrote:
it is not possible to "override" build-in object types. A third party renderer typically introduces a custom tag that can be added to a light object to provide additional parameters.
One can of course create an ObjectData based plugin that draws something in the viewport. This is done by implementing ObjectData::Draw(). You find some examples in the Draw Manual and the example projects like "Gravitation".
best wishes, Sebastian
On 22/11/2016 at 05:24, xxxxxxxx wrote:
Hello.
How can I make the ObjectData operate as light in the viewport ? I want to illuminate only specific parts of the scene and create shadows behind the other objects.
I add a GetVirtualObjects method in my ObjectData plugin and I return an Olight object. I can modify this Light Object using my Object Data parameters, but I cannot control it in the viewport.
The Cinema 4D spot light can be configured in the viewport using the dots that control the inner/outer angle. How can I create such viewport controls ?
Thank you again.
On 22/11/2016 at 08:33, xxxxxxxx wrote:
such "viewport controls" are called handles. They are implemented with GetHandleCount() / GetHandle() / SetHandle(). You find some examples in the SDK example project like the "Circle" example.
For questions no longer related to the thread's original topic please open a new thread. Thanks.
