On 09/11/2016 at 09:07, xxxxxxxx wrote:
--------- Hi, I'm trying to embed a falloff into a plugin, but it appears that nothing except for C4D_Falloff::AddFalloffToDescription() has any effect. I can see the Falloff description, but besides that, nothing else works.
The falloff parameters are not initialized, no handles are displayed, the description doesn't act dynamically as it usually does (eg. showing different parameters when choosing a different falloff type), etc.
Does someone have an example of how to do this correctly? My attemp below
#pragma once #include "c4d.h" #include "c4d_falloffdata.h" class FalloffObjectData : public ObjectData { protected: AutoAlloc<C4D_Falloff> falloff; public: // ObjectData Overrides virtual DRAWRESULT Draw(BaseObject* op, DRAWPASS pass, BaseDraw* bd, BaseDrawHelp* bh) override { if (!op) return DRAWRESULT_ERROR; auto* bc = op->GetDataInstance(); if (!bc) return DRAWRESULT_ERROR; if (!this->falloff->Draw(bd, bh, pass, bc)) return DRAWRESULT_ERROR; return DRAWRESULT_OK; } virtual Int32 GetHandleCount(BaseObject* op) override { if (!op) return 0; auto* bc = op->GetDataInstance(); if (!bc) return 0; return this->falloff->GetHandleCount(bc); } virtual void GetHandle(BaseObject* op, Int32 index, HandleInfo& info) override { if (!op) return; auto* bc = op->GetDataInstance(); if (!bc) return; this->falloff->GetHandle(index, bc, info); } virtual void SetHandle(BaseObject* op, Int32 index, Vector pos, HandleInfo const& info) override { if (!op) return; auto* bc = op->GetDataInstance(); if (!bc) return; this->falloff->SetHandle(index, pos, bc, info); } // NodeData Overrides virtual Bool Init(GeListNode* node_) override { if (!this->falloff) return false; auto* op = static_cast<BaseObject*>(node_); if (!op) return false; auto* bc = op->GetDataInstance(); if (!bc) return false; BaseContainer* falloff_vals = this->falloff->GetContainerInstance(); if (!falloff_vals) return false; bc->MergeContainer(*falloff_vals); return ObjectData::Init(node_); } virtual Bool GetDDescription(GeListNode* node_, Description* desc, DESCFLAGS_DESC& flags) override { auto* op = static_cast<BaseObject*>(node_); if (!op || !desc) return false; auto* bc = op->GetDataInstance(); if (!bc) return false; if (!desc->LoadDescription(op->GetType())) return false; flags |= DESCFLAGS_DESC_LOADED; if (!this->falloff->AddFalloffToDescription(desc, bc)) return false; return ObjectData::GetDDescription(node_, desc, flags); } virtual Bool Message(GeListNode* node_, Int32 msg, void* pdata) override { auto* op = static_cast<BaseObject*>(node_); if (!op) return false; auto* bc = op->GetDataInstance(); if (!bc) return false; if (!this->falloff->Message(msg, bc, pdata)) return false; return ObjectData::Message(node_, msg, pdata); } };
Thanks, -Niklas
On 10/11/2016 at 05:23, xxxxxxxx wrote:
it seems that you have to handle the falloff object also in some additional functions.
best wishes, Sebastian
On 10/11/2016 at 06:31, xxxxxxxx wrote:
Hi Sebastian,
thanks for the reply.
#pragma once #include "c4d.h" #include "c4d_falloffdata.h" class FalloffObjectData : public ObjectData { protected: AutoAlloc<C4D_Falloff> falloff; Int32 falloff_dirty; Bool InitFalloff(GeListNode* node_) { if (!this->falloff) return false; auto* op = static_cast<BaseObject*>(node_); if (!op) return false; auto* bc = op->GetDataInstance(); if (!bc) return false; return this->falloff->InitFalloff(bc, op->GetDocument(), op); } Int32 GetFalloffDirty(GeListNode* node_) { if (!this->falloff) return false; auto* op = static_cast<BaseObject*>(node_); if (!op) return false; auto* bc = op->GetDataInstance(); if (!bc) return false; return this->falloff->GetDirty(bc); } public: FalloffObjectData() : ObjectData(), falloff(), falloff_dirty(0) {} virtual ~FalloffObjectData() {} // ObjectData Overrides virtual DRAWRESULT Draw(BaseObject* op, DRAWPASS pass, BaseDraw* bd, BaseDrawHelp* bh) override { if (!this->InitFalloff(op)) return DRAWRESULT_ERROR; BaseContainer* bc = op->GetDataInstance(); if (!this->falloff->Draw(bd, bh, pass, bc)) return DRAWRESULT_ERROR; return ObjectData::Draw(op, pass, bd, bh); } virtual Int32 GetHandleCount(BaseObject* op) override { if (!this->InitFalloff(op)) return 0; BaseContainer* bc = op->GetDataInstance(); Int32 count = this->falloff->GetHandleCount(bc); return count; } virtual void GetHandle(BaseObject* op, Int32 index, HandleInfo& info) override { if (!this->InitFalloff(op)) return; BaseContainer* bc = op->GetDataInstance(); this->falloff->GetHandle(index, bc, info); } virtual void SetHandle(BaseObject* op, Int32 index, Vector pos, HandleInfo const& info) override { if (!this->InitFalloff(op)) return; BaseContainer* bc = op->GetDataInstance(); this->falloff->SetHandle(index, pos, bc, info); } virtual void CheckDirty(BaseObject* op, BaseDocument* doc) override { ObjectData::CheckDirty(op, doc); Int32 dirty_count = this->GetFalloffDirty(op); if (dirty_count != this->falloff_dirty) { this->falloff_dirty = dirty_count; op->SetDirty(DIRTYFLAGS_DATA); } } // NodeData Overrides virtual Bool Init(GeListNode* node_) override { if (!ObjectData::Init(node_)) return false; if (!this->InitFalloff(node_)) return false; return true; } virtual Bool GetDDescription(GeListNode* node_, Description* desc, DESCFLAGS_DESC& flags) override { if (!ObjectData::Init(node_)) return false; if (!desc || !desc->LoadDescription(node_->GetType())) return false; flags |= DESCFLAGS_DESC_LOADED; if (!this->falloff->AddFalloffToDescription(desc, nullptr)) return false; return ObjectData::GetDDescription(node_, desc, flags); } virtual Bool Message(GeListNode* node_, Int32 msg, void* pdata) override { if (!this->InitFalloff(node_)) return false; if (!this->falloff->Message(msg, nullptr, pdata)) return false; return ObjectData::Message(node_, msg, pdata); } };
Edit:
On 13/11/2016 at 10:17, xxxxxxxx wrote:
And all this info straight into the docs for future reference.. ;)
