On 05/11/2016 at 18:35, xxxxxxxx wrote:
Hello Forum,
I'm writing a script to resize a rig and would like to send c4d.ID_CA_WEIGHT_TAG_SET to a weigh tag.
I found this C++ link: https://plugincafe.maxon.net/topic/5222/5217_reset-bind-pose&KW=set+bind+pose&PID=21410#21410
This does not work:
tag.Message(c4d.MSG_DESCRIPTION_COMMAND, c4d.DescID(c4d.DescLevel(c4d.ID_CA_WEIGHT_TAG_SET)))
Python Error:
Traceback (most recent call last) : File "'active-layer.pypv'", line 515, in CoreMessage File "'active-layer.pypv'", line 176, in ActiveLayerIsOn TypeError: C4DAtom.Message expected dict, not c4d.DescID
So I made a guess and this seems to work:
tag = op.GetTag(c4d.Tweights) data = dict() data['id'] = c4d.ID_CA_WEIGHT_TAG_SET tag.Message(c4d.MSG_DESCRIPTION_COMMAND, data)
Is this the correct way to Message() a C4DAtom with a script?
Thank you,
Joe Buck
On 07/11/2016 at 02:38, xxxxxxxx wrote:
Hi Joe,
there's nothing wrong with your solution. A bit shorter, the same could be achieved by using CallButton(), but there's really no difference otherwise.
On 07/11/2016 at 07:00, xxxxxxxx wrote:
Thanks Andreas.
