On 02/11/2016 at 15:25, xxxxxxxx wrote:
User Information: Cinema 4D Version: 18 Platform: Language(s) : PYTHON ;
--------- If I try to send a modeling command with c4d.ID_MODELING_BEVEL_TOOL I always get a False result. However, if I use the command ID: 431000015, I get the expected bevel.
It seems like the Command ID hasn't been updated? If it has, then the recommended command ID should be updated in the Documentation for Send Modeling Command.
"""SimpleBevel Bevels the selected polygon object. """ import c4d from c4d import gui def Bevel(op, offset=10.0, subdivision=0) : if op is None: return False settings = c4d.BaseContainer() settings[c4d.MDATA_BEVEL_OFFSET_MODE] = c4d.MDATA_BEVEL_OFFSET_MODE_FIXED settings[c4d.MDATA_BEVEL_RADIUS] = 10.0 settings[c4d.MDATA_BEVEL_SUB] = subdivision settings[c4d.MDATA_BEVEL_EXTRUSION] = offset settings[c4d.MDATA_BEVEL_POLY_ANGLE] = c4d.utils.Rad(91.0) settings[c4d.MDATA_BEVEL_GROUP] = True c4d.utils.SendModelingCommand(command = c4d.ID_MODELING_BEVEL_TOOL, list = [op], mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, bc = settings, doc = doc) def main() : Bevel(op) c4d.EventAdd() if __name__=='__main__': main()
On 03/11/2016 at 03:21, xxxxxxxx wrote:
Hi Donovan,
thanks for pointing this out.
Actually ID_MODELING_BEVEL_TOOL is still pointing to the old bevel tool and this can't be used with SendModelingCommand(). So, the behavior you see with that ID is actually not a bug. In C++ docs this is noted down, unfortunately the comment is missing in the Python docs. This will be fixed. Additionally ID_MODELING_BEVEL_TOOL should (and will) be marked as deprecated. A define for the ID (431000015) of the new bevel tool is unfortunately missing, yet. It will be added with one of the next releases.
Sorry for the inconvenience this may have caused.
