External class refresh
On 26/10/2016 at 02:38, xxxxxxxx wrote:
Hi I'm currently building a plugin structured as that:
plugin.pyp
../class/MaClass.py
I included succefully into my project and everthing is working nice.
The only annoying things is I need to close / re-open C4d for the change made in MaClass.py have an effect.
Moreover I saw on the start it generate some pyc file. I tried to recreate them with py_compile but that affect nothing...
So my ask is there a way for have something dynamic as a pyp file is? 🙂
Thanks in advance.
Another thing out of context:
https://developers.maxon.net/docs/Cinema4DPythonSDK/html/modules/c4d.storage/index.html#c4d.storage.LoadDialog
title is not described into Parametter but listed in the call.
On 27/10/2016 at 01:28, xxxxxxxx wrote:
the "Reload" function currently only reloads the pyp files. *.py files are not re-evaluated (only on startup). So currently I don't see a way to reload *.py files at runtime.
Thanks for reporting the issue in the documentation. For further bug reports (also on the documentation) please use the Bug Reports subforum.
best wishes,
Sebastian
On 27/10/2016 at 10:06, xxxxxxxx wrote:
Please take a look at this post: Best Practice for Imports
If you use the  localimport  class, your external Python modules will automatically reload.
The newest minified version can be found here: https://gist.github.com/NiklasRosenstein/f5690d8f36bbdc8e5556
Example:
# localimport-v1.5_b64_lw=99
exec("""import base64 as b, zlib as z; s={}; blob=b"\neJydGctu20bwrq8gkAPJmKXjBr0IZVCkSIGiRQ5B0UMFgqDIpbw1RRK7q9SykX/vzOyTItU4vVjL3ZnZeT/W/DiNQkXNOJ2zQz/\nus1Fm08PhpHifybPMlKgbtq+bh+yJTx3v2abpaymjfmzqnhNyMu7/Zo1Kt5uoquqTuh9FVRXxR/4AkNGnUbJBKsaH6Efh1gMd/n\nQ41rzPm/H4Lkbkz0xIPg6IfZf/gFvT+e1DAXzk9ogP3bh7U74r3sKpVIIPh0qdJyaLBL6ylHcaKWK9ZMm+lkwDZekmahkcAgWuq\niqRrO+yqVb38EewQVUtF8XHcWBZO1bscJDFH+JEH5O6pzUKGAH9YVSRx8HNqBP1kRGf1YEp+kru0ryrUKV1LxEGMOOqQhVWVRyB\nOgiM0ANyxShz5CqH9YBk7He9l/ibENbOUypTkCxCaQiu2JWaSy45qLoeGpaQlAQx0xjJE2kk/IuI3Shop8K7kUn82Br2UXDLDpf\nAUOJANa0r2okiUXPJoj/r/sQ+CDGKJBasrxX/zOiCaH9SgBjgxanRi6Hv1PL3yIfEw2Weg80q/DCKI+ltDuj0ldfTxIb24hjkMF\n6gBfDg7FEhONo1xz/JBWOGSha/zgE9Tr11jkzVlTeR3hvbUw+++/zF7hh/0z92kw9VMw4K7i5+AW9i1pVBCUwYXyYLKHHWxtJRD\nYFcCSbHk2gY+eAgW96oAqM9bxmbcJHMoHJiH1ytYcBs81AfwFEQtWUQ+IL542KOtzgne/w3SKGdcg2VPTZsUtGvJAj5zDYQAON0\nnSlzQoTB/RUrnmONFG/1bxYvsOLtYisDLDSWjLfPX7IYl/EWAxxXu22Zxc6eet990mGL8QGWNdg6oRrnMUgrmxm5gb+kcH5n9sN\nLirlX3czON6T7S/pG38GOCfkHds7AFzHgQ7/MuWJHmejgRt/yat15EcsdoJeU/SzeNE4JbJLjGEv+xs7ajBOUDwpBD68JwIdOXU\nEg6Ox6mZScWnR04nk34MFLwhKoQliaxGQU8rnu8bakG+YJxdripgglJ/uVK6oLNBBqDkQiCBmhd5qML1jHHwvAzgWkM8UVVLckz\nuMUqpvNpfe1rJUSSUgY6kuikdMMqgCxW8VWnpb1C8WSEfqAHBwuUUMBreuXzjC5BQfHI/Bwr1hxtSQEyPQHarWq0pWshuUVtgVT\nJ6HN61Lco6/WrwE5qMEXREgMXWg+nQbFj7bUmHPCoYzJWiov1MIQh1KnZOtn1pZh7aN9pGDdb+YLWoUBwbCspIY0BqdzExuozkH\noUDrBonpo9ebKpT71lK7uLmDnV1wWIcsgbiCDthKFrkbVIV36+ZqPAwhWjHGyFQq2oEGhWgwuG/qdaVwyDAZbbZFxC0+iw3VOGm\nBpf+K9Alvrq3WaDlsnHUhy6rnCIMruwjDSIAHnRiNrDFLUaIRylVlqLC0BJ7RxYLzNbUbgfDOZdLLhsiJHcWdZ4DdpGI2z7Hglv\nYbbp6kF90jWk/SKHdcBF0nfdFukKVSz03K6++77Mkjxvw4te7RJ3uPYYu0sUTmNhN/zBDozbpjRApTSqEobTx9klxzelShuKL0L\n8bWMtyx5F9k0yHq6fl4rcIs6flk91gv6MsT/q5ZbmisNRvmCfvBF/Zn1kEXXVC5JrHSPedOzWiTpy4BXfNi0b+TBK22hVfd6o6w\nroqNmyoqLQaorLhBRbz2XNMr67LCYwMyB9anFvIQk3GxVrdJYjBsuN8jTfnZL0JDomDBFcl4yw7HAdTNz4SR4NkxMYQX1wxxCec\nF0KSXKsPqHQ7yMUC08TzEMaDDbd5PrzzjGftbzgbTAhtORCTRkN/nREE/RDEJJpJnE2i1d84LnVTcU8fObL6+e777EOVA+1srfS\n7fc3OlE7LybYpA1UTMeJ5QD6WSGWBbjkRknrfu8ryX7QEtouiwJ99KRTzAjK+g8mmSR8YmBggTpYJ3EryxpHLnx8N2bLR4TzG5L\nW6UXrzA6EHxKPOJysEYwqxaNOGtoLx8JnOVI7HSzRHNzcABgTEKZmBZBwQ0aB/cN4SWZUMkbewu52yIv2KcVimjvuV/JJckMQXc\nkF4nfn5ebb+1AL6jrQAmANc8wgjl+EeSJT5UJjid/EuEKug2yYnyrPcAEos0DTzmuMBOQnaflI8ZrouJLFYI9ERiQ1CArEPR6NZ\n2L2D5kxTdAFSSRbLqJp3PsYZqrQE0ANV6FGmOtZV1uSJTJd7PXGmXzTAh+XJmlboK1M/mQZYdDYWH/4tMvFpByiwap25auTgIzA\nFpGWrqJby3fOYidAktfB2teCDdqZWNuIw4W06R+OXxyGZxEN/xSPHXhwGCVaAPKftsmvLNjgs1QidXM+7r9Sy/t+2v+ey0OzGjM\npgisgdFmlqqu8e1ZBo590oFMou2k27KrvDubXNSO5U3Gv1LU+EuBm2+CHtN0Xfnfonureh2/u0W+fEzR2x9DUpB9fsJExhvo0u7\nx1cI2FbZ4E5e1fKhswbV+L1g/M4z5niP4Pse/mAYlWRf7yBd/SxSpNicBJGD0IPnNSVh06Wahr0G2TeOvE6DOtWGLEDwj68OrD8\nk7/WxjyM3VBnjlrKcARVXmCUQf30CCC8ZQehB9+fMKQBWGUKSRQpH9ZUEWCicUuFt718XwsIXpIQzLr0040XH5nvW/5p7l4LN5F\nf0sGBTPNtqfo+l8hBjoOBNRcq/UJLe3twcQ9bTHf6bc9rxTY9fderB0s/kXDFzgoQ=="
exec(z.decompress(b.b64decode(blob)), s)
localimport=s["localimport"]; del blob, b, z, s;""")
with localimport('.') as importer:
  importer.disable(['MaClass'])
  import MaClass
Of course you are free to use the original uncompress or unminified source as well.
Regards,
Niklasl
On 28/10/2016 at 10:27, xxxxxxxx wrote:
Thans you niklas is working fine 🙂
A little suggestion it would be nice to be able to indent the code.I oftenly do if bool(1) : like that I can show  / hide some portion of my code in sublime 😉 Not best practise but I like it ^^
Since you didn't finnish all the lines when you indent the code it interpret it as indent into your code and not into the string.
But it's just a detail who can be mannualy fixed ! Anyway thanks you 🙂
EDIT : another things if in the subfile I use a module (for exemple c4d) and I imported c4d in the main file. If in the subfile I didn't import c4d it don't show any error but it's not working 😉
