Multi paragraph text in .str files
On 21/10/2016 at 05:12, xxxxxxxx wrote:
Cinema 4D Version: R18
Platform: Windows ;
Hello.Can I have a text paragraph as STATICTEXT in a NodeData plugin ?
I have tried using \n but it doesn't work.Thank you.
On 24/10/2016 at 01:57, xxxxxxxx wrote:
in your resource file you'd use a STRING with CUSTOMGUI MULTISTRING. Additionally add the READONLY flag to mimic the static text behavior.
Like so:STRING MY_PARAGRAPH { ANIM OFF; CUSTOMGUI MULTISTRING; WORDWRAP; READONLY; }
Inside of the string you can use the pipe symbol ("|") for newline.
On 10/08/2017 at 18:53, xxxxxxxx wrote:
Hi all,
Andreas, is still valid the pipe symbol for the newline?
Thanks in advance
Renato
On 11/08/2017 at 02:17, xxxxxxxx wrote:
Hi Renato,
I'm not aware of any changes on our end. But as you are asking, you are probably having problems with it?
On 11/08/2017 at 09:21, xxxxxxxx wrote:
Hi Andreas,
yes, i'm trying to output some lines to:
STRING MY_TEXT_INFO { ANIM OFF; CUSTOMGUI MULTISTRING; WORDWRAP; READONLY; }adding the Pipe Symbol.. but the output is with pipe instead a newline:
here the example:
Grid Name: density - Grid Class: unknown | Grid Name: temperature - Grid Class: unknown | Grid Name: v - Grid Class: unknown |would be good to have:
On 11/08/2017 at 18:07, xxxxxxxx wrote:
If you create the string in your code, you need to use
actual newlines.
On 11/08/2017 at 19:49, xxxxxxxx wrote:
Hi Niklas, what do you mean with "actual newline" ?
I tried to construct my string with '\n' without luck.
On 12/08/2017 at 17:59, xxxxxxxx wrote:
I'm sorry... but maybe too hot in the brain.
Thanks all for your time :)
On 14/08/2017 at 08:49, xxxxxxxx wrote:
just for future readers, as it might not be completely clear: When setting a multi-line string parameter via code, one needs to use newline '\n' to add additional lines. While in the string file it is the pipe symbol '|'.
I will add this information also to one of the code examples.
On 14/08/2017 at 09:57, xxxxxxxx wrote:
Thanks Andreas :)
On 25/08/2017 at 11:56, xxxxxxxx wrote:
I was just giving this a try in a c4d_strings.str stringtable. I get the string with the Pipe symbol still in
the text (using GeLoadString in Python), rather than it being replaced by a newline. Does this only work
in C++ or in description/dialog stringtables?Thanks!
On 29/08/2017 at 08:20, xxxxxxxx wrote:
Hi Niklas,
indeed GeLoadString() does not care for line wraps, neither in C++ nor in Python.
A small helper function could look like this:static String GeLoadStringUpd(Int32 id) { Int32 i; String str = GeLoadString(id); for (i = str.GetLength() - 1; i >= 0; i--) { if (str[i] == '|') { str.Delete(i, 1); str.Insert(i, GeGetLineEnd()); } } return str; }
On 30/08/2017 at 02:31, xxxxxxxx wrote:
for me, \u000d works to create a line break in a str file.
