Handling MessageData.GetTimer() event
  • On 15/10/2016 at 17:29, xxxxxxxx wrote:
    Hi everyone.
    I'm trying to create timer that runs a function twice a second.
    Here's the code of my plugin:
    from c4d import plugins
    PLUGIN_ID=123454321
    class MyMsg(c4d.plugins.MessageData) :
      def GetTimer(self) :
          return 500
    def CoreMessage(self, id, bc) :
          if id==PLUGIN_ID:
              MyFunction()
    def MyFunction() :
      print "tick"
    if __name__=="__main__":
      plugins.RegisterMessagePlugin(PLUGIN_ID, "TestPlugin", 0, MyMsg())
    I can't figure out how to create and handle timer event. Is it possible? What am I doing wrong.
    Would appreciate any help.
    Have a nice day.
  • On 16/10/2016 at 07:15, xxxxxxxx wrote:
    Try it like this
    from c4d import documents, plugins
    PLUGIN_ID = 1000000
    class MyMessage(plugins.MessageData) :
      def __init__ (self) :
          self.object = None
          return 500
          if id == c4d.MSG_TIMER:
              print "Timer Executed"  #<---Put the call to your function here
      plugins.RegisterMessagePlugin(id=PLUGIN_ID, str="Message Plugin", info=c4d.PLUGINFLAG_SMALLNODE, dat=MyMessage())
  • On 16/10/2016 at 09:41, xxxxxxxx wrote:
    Thanks a lot, Scott, but there is 1 problem with the code you gave me: Event fires up about 20 times per second, not twice.  Should I check the time manually, or what?
    *There's not a single word about "c4d.MSG_TIMER" in Maxon's python documentation.
  • On 16/10/2016 at 10:09, xxxxxxxx wrote:
    The GeTimer() executes in milliseconds.
    Change return 500 to whatever value you want.
    Try something like 2000 for starters.
    There's an example of this in the C++ docs.
    Sometimes the answer to a Python question can be found in there.
  • On 16/10/2016 at 10:18, xxxxxxxx wrote:
    Scott, I'm afraid you didn't understand me. Please pardon my english - it's not my native language. :)
    Let me repeat myself: YOUR code (with "return 500" statement) fires up about twenty times per second. Is it bug?
    *R17.053
  • On 16/10/2016 at 10:30, xxxxxxxx wrote:
    Hopefully this will be clearer.
    PLUGIN_ID = 1000000
          self.object = None
          timerValue = 2000    #<--- Change this value to change how long to wait between executions
          return timerValue
  • On 16/10/2016 at 10:44, xxxxxxxx wrote:
    "Lost in translation" as is.:)
    This code My target function   fires up 20 times per second with no matter of return value in GetTimer() method:
          return 500
    and
          return 5000
    and even
          return 50000
    are giving the same result. Looks like a bug to me.
    Don't you have such a problem on your PC?
  • On 16/10/2016 at 11:04, xxxxxxxx wrote:
    Working properly for me in R13.
    Increasing the timer value makes it wait longer between executions as expected.
    Are you running this in the script manager?
    The code I posted is a plugin. The code should be saved in a .pyp file and then place in the plugins folder.
  • On 16/10/2016 at 11:12, xxxxxxxx wrote:
    LOL. Of course I'm running this code as a plugin. I think that it's a little bug in R17 and combining this code with the c4d.GeGetTimer() gonna give me the desired result.
    Anyway thanks a lot - you really helped me very much.
    UPD: I've sent a bug report about this problem.
  • On 17/10/2016 at 07:40, xxxxxxxx wrote:
    there's indeed a bug in the Python layer.
    See related thread: here
