Check if the current C4D version is >= R16 Version
On 12/10/2016 at 15:38, xxxxxxxx wrote:
I wrote this script to check if the current version of Cinema 4D is greater or equal to R16.
can I improve this script or there is a better way of doing this?import c4d def main() : if int(str(c4d.GetC4DVersion())[:2]) >= 16 : print "Greater than or equal to R16" else : print "Older than R16" if __name__=='__main__': main()
Thanks
On 12/10/2016 at 16:15, xxxxxxxx wrote:
The number you get with GetC4DVersion() is the Cinema 4D version number multiplied by 1000.
So your check can be optimized like this:if c4d.GetC4DVersion() >= 16000: # ...
Best,
Niklas
On 12/10/2016 at 16:22, xxxxxxxx wrote:
Thank you, I had not thought about that.
Best
