On 05/10/2016 at 06:37, xxxxxxxx wrote:
Hi Peterakos, thanks for writing us.To browse through the parameters belonging to DOCUMENTSETTINGS_GENERAL you can use the GetData() method to retrieve the BaseContainer and using a BrowseContainer object you can iterate and return the id/value of those parameters and matching the ID to the values found in ddoc.h get an understanding of their purpose.
GeData* dataPtr = nullptr;
Int32 id = 0;
// Retrieve the BaseContainer where to access the DOCUMENTSETTINGS_GENERAL params
BaseContainer bcGenData = doc->GetData(DOCUMENTSETTINGS_GENERAL);
// Allocate a BrowseContainer object, initializing with the reference to retrieved BaseContainer
BrowseContainer containerBrowser = BrowseContainer(&bcGenData );
// Loop through all parameters stored
while (containerBrowser.GetNext(&id, &dataPtr))
if (dataPtr)
... and do something with the data retrieved
With reference to the second part of the question, I confirm that if you change the value of one of the parameters belonging to DOCUMENTSETTINGS_GENERAL once you copy or clone the document the parameter in the new document is populated with the new value. Please take care of calling the SetData() method after updating the value any parameter stored in DOCUMENTSETTINGS_GENERAL.
// Change the value of the project FPS
bcGenData.SetParameter(DOCUMENT_FPS, Int32(66));
// Update the values in the document
doc->SetData(DOCUMENTSETTINGS_GENERAL, bcGenData);
GeData docFPSData;
// Allocate a new BaseDocument instance
BaseDocument* copiedDocPtr = BaseDocument::Alloc();
if (nullptr == copiedDocPtr)
return false;
// Copy the old document on the new document
doc->CopyTo(copiedDocPtr, COPYFLAGS_0, nullptr);
// Retrieve the BaseContainer for the new document referred to DOCUMENTSETTINGS_GENERAL
BaseContainer bcNewCopyGenData = copiedDocPtr->GetData(DOCUMENTSETTINGS_GENERAL);
// Populate the GeData object with the values belonging to param DOCUMENT_FPS
bcNewCopyGenData.GetParameter(DOCUMENT_FPS, docFPSData);
// Print the value
GePrint("FPS in copied doc is: " + String::IntToString(docFPSData.GetInt32()));
// Deallocate the new doc
BaseDocument::Free(copiedDocPtr);
Best, Riccardo
