On 29/08/2016 at 11:09, xxxxxxxx wrote:
Does anyone have a creative way of accessing material "selection"? I couldn't find a method in the Python SDK or in C++ so maybe there's a workaround?
I appreciate any suggestions.
http://www.dropbox.com/s/vfim279j1j3hc3q/Screen Shot 2016-08-29 at 11.05.00 AM.png?dl=0
On 29/08/2016 at 15:03, xxxxxxxx wrote:
Hi, You can LMB click on most attributes and drag & drop them into the bottom the of the Console or into the script manger to get a rough idea how to get at them.
Try this:
import c4d def main() : obj = doc.GetActiveObject() if obj is None: return false ttag = obj.GetTag(c4d.Ttexture) if ttag is None: return false if ttag: selection = ttag[c4d.TEXTURETAG_RESTRICTION] print selection c4d.EventAdd() if __name__=='__main__': main()
On 29/08/2016 at 15:26, xxxxxxxx wrote:
Totally forgot about this! Thanks Scott.
On 30/08/2016 at 01:25, xxxxxxxx wrote:
as Scott shows the "Selection" parameter of a texture tag is just an ordinary parameter that can be accessed like any other parameter. It is just a simple string storing the name of the referenced selection tag. You find some C++ examples on how to handle a texture tag in the TextureTag Manual.
Best wishes, Sebastian
