Filename concatenation eats folder parts
  • On 23/08/2016 at 13:26, xxxxxxxx wrote:
    Cinema 4D Version:   R17
    Platform:   Windows  ;
    Hi everyone,
    I was integrating GenerateTexturePath to my assets and have noticed one confusing thing with filename concatenation when I wanted to concanate a project directory path and filename relative path (including subfolders) and the filename itself.
    	Filename doc_dir = doc>GetDocumentPath();
    	Filename suggested_dir = texFilename.GetDirectory();
    	Filename src_file = texFilename.GetFile();
    	Filename dst_name;
    	Filename dir2 = doc_dir + suggested_dir;
    	printf("\n doc_dir: %s",		doc_dir.GetString().GetCStringCopy());
    	printf("\n src_file: %s",		src_file.GetString().GetCStringCopy());
    	printf("\n suggested_dir: %s",	suggested_dir.GetString().GetCStringCopy());
    	printf("\n dir2: %s",			dir2.GetString().GetCStringCopy());
    It prints for given filename ./folder1/folder2/12.jpg typed to FILENAME field
    doc_dir F:\Development	est scenes
    suggested dir: ./folder1/folder2
    dir2: F:\Development	est scenes\folder2
    But why dir2 is F:\Development est scenes\folder2???
    It should be dir2: F:\Development est scenes\folder1\folder2 instead
  • On 25/08/2016 at 01:43, xxxxxxxx wrote:
    it appears that the "+" or "+=" operator of the Filename class only adds the last part of the given Filename which is typically the actual name of the file. As far as I can see you would have to deconstruct the second Filename and add every part manually. This is some rough implementation you can use as a starting point to build your own solution. Don't forget to test this on all supported platforms:
    Filename       fullPath  = Filename("F:\\Development\\test scenes");
    const Filename extraPath = Filename("./folder1/folder2");
    const String extraPathString = extraPath.GetString();
    Int32 start = 0;
    Int32 found = 0;
    // loop through filename parts
    while (extraPathString.FindFirst("/", &found, start))
      String subStr = extraPathString.SubStr(start, found - start);
      if (subStr != ".")
      fullPath += subStr;
      start = found + 1;
    // add rest
    const Int32  length = extraPathString.GetLength();
    const String subStr = extraPathString.SubStr(start, length - start);
    fullPath += subStr;
    GePrint("result: " + fullPath.GetString());
    best wishes,
    Sebastian
