On 18/08/2016 at 09:12, xxxxxxxx wrote:
--------- Hi,
I would like to add Post Effects under Multi-Pass using the code:
rd->SetParameter(RDATA_MULTIPASS_ENABLE, 1, DESCFLAGS_SET_0); // Enable the multi pass option MultipassObject *mpo = NULL; mpo = (MultipassObject* )MultipassObject::Alloc(Zmultipass); if (mpo) { BaseContainer *mdata = mpo->GetDataInstance(); mdata->SetInt32(MULTIPASSOBJECT_TYPE, VPBUFFER_POSTEFFECT); // GeData data; // data.SetInt32(VPBUFFER_POSTEFFECT); // mpo->SetParameter(DescID(MULTIPASSOBJECT_TYPE), data, DESCFLAGS_SET_0); doc->StartUndo(); rd->InsertMultipass(mpo, NULL); doc->AddUndo(UNDOTYPE_NEW, mpo); doc->EndUndo(); rd->Message(MSG_UPDATE); EventAdd(); }
But it adds only an empty line under Multi-Pass. Even using currently commented SetParameter doesn't help. How to add it programmably?
My example is based on https://plugincafe.maxon.net/topic/5716/5761_multipassobject-allocation&KW=MULTIPASSOBJECT_TYPE&PID=24000#24000 which works well for RGBA, but I need Post Effects too! Please, help.
On 19/08/2016 at 06:06, xxxxxxxx wrote:
you are using the wrong MULTIPASSOBJECT_TYPE. Instead of VPBUFFER_POSTEFFECT (which is used with AllocateBuffers()) you need to use VPBUFFER_ALLPOSTEFFECTS. There is no option to add a MultipassObject just for one single specific VideoPost. Some more information can be found in the MultipassObject manual.
On 19/08/2016 at 06:52, xxxxxxxx wrote:
Hi Andreas, thanks a lot, will try it just now!
Btw, I have noticed that when Multi-pass is enabled by user or programmably then C4D applies pow(pix, 1.0f/2.2) to all the single layers and results of operations on layers. And this doesn't happend when Multi-pass is disabled (i.e. single image). Btw, does Cinema use 2.2 or pricise srgb curve? If uses 2.2 then can user change it in the settings?
On 19/08/2016 at 06:58, xxxxxxxx wrote:
Andreas, thank you very much! It works!
On 19/08/2016 at 23:45, xxxxxxxx wrote:
Originally posted by xxxxxxxx Hi, you are using the wrong MULTIPASSOBJECT_TYPE. Instead of VPBUFFER_POSTEFFECT (which is used with AllocateBuffers()) you need to use VPBUFFER_ALLPOSTEFFECTS. There is no option to add a MultipassObject just for one single specific VideoPost. Some more information can be found in the MultipassObject manual.
Thanks a lot Andreas! - Was facing same issue, all sorted now.
