Col/row span of dialog elements
On 11/08/2016 at 04:23, xxxxxxxx wrote:
Cinema 4D Version: R17
Platform:
Language(s) : C++ ; PYTHON ;---------
Is it possible to specify the column (and eventually row) span for an element in a GeDialog?
It is (sort of) possible in a description resource by filling the columns to be filled by the previous
element with STATICTEXT{JOINEND;} or STATICTEXT{JOINENDSCALE;}.Right now I have a group with 2 columns filled with a few widgets, and I'd like to add a separator
that is rendered in a single line. Currently I have to add two separators (because 2 columns) and
thus the separator line has a break.Thanks,
Niklas
On 12/08/2016 at 04:30, xxxxxxxx wrote:
Hi Niklas,
I'm not aware of something like this for a dialog.
But for your separator problem, couldn't you address this by reorganizing the groups? I mean, something like one single column parent group. And in there several two column groups and the separator(s) in between.
On 13/08/2016 at 00:13, xxxxxxxx wrote:
Hi Andreas,
thanks for the info.
That would "work", but it wouldn't look as nice because the columns would not have consistent widths. :(
Niklas
