On 09/08/2016 at 16:13, xxxxxxxx wrote:
User Information: Cinema 4D Version: R13+ Platform: Windows ; Mac ; Mac OSX ; Language(s) : C++ ; PYTHON ;
--------- Howdy,
Is it possible to create a python extension function that takes an integer for the first parameter, and then a variable parameter for a second parameter, like I can do with a coffee extension function?
For instance if I want the first parameter to be an ID, and then the second parameter to be either a bool, integer or float. Is that possible?
Adios Cactus Dan
On 09/08/2016 at 18:16, xxxxxxxx wrote:
Howdy,
OK, never mind. I took an educated guess and it worked perfectly:
LONG id; GeData gdata; const CHAR *kwlist[] = {"integer", "gedata", NULL}; if(!pylib.ParseTupleAndKeywords(args, keywords, "iG", kwlist, &id, &gdata)) return pylib.ReturnPyFALSE(); if(gdata.GetType() != DA_LONG && gdata.GetType() != DA_REAL) return pylib.ReturnPyFALSE();
The last line checks the type, so the function only accepts a bool, int or float (a bool is actually an int).
Adios, Cactus Dan
On 10/08/2016 at 02:31, xxxxxxxx wrote:
Yes, using a GeData is the way to go in Python to parse a parameter that can be of various types.
On 10/08/2016 at 05:45, xxxxxxxx wrote:
Well, the educated guess was mainly in the use of the string "gedata". I sort of knew that a GeData was the way to go.
That's why I asked in the other thread if you could post a complete list of parameters for the different types.
