On 02/08/2016 at 12:02, xxxxxxxx wrote:
Supposedly I can only get some types of values from GeDialog items. Namely:
GeDialog.GetBool() GeDialog.GetLong() GeDialog.GetInt32() GeDialog.GetReal() GeDialog.GetFloat() GeDialog.GetVector() GeDialog.GetString() GeDialog.GetColorField() GeDialog.GetTime() GeDialog.GetFilename() GeDialog.CheckTristateChange()
But I have a LINK field. How can I get a value from it?
On 02/08/2016 at 12:03, xxxxxxxx wrote:
You get the LinkBoxCustomGui with GeDialog.FindCustomGui() then use LinkBoxCustomGui.GetLink().
Cheers, Nik
On 02/08/2016 at 14:15, xxxxxxxx wrote:
Hello Niklas. Thank you for the answer. I have tried it but I get True, instead of a LinkBoxCustomGui. I read in the SDK that...
Note: Returns True if the custom GUI was found in the dialog but its type is unknown by Python and cannot be returned.
My dialog is defined by a res file, not by a AddCustomGui() and the SDK also says that:
"Get the custom GUI for a certain ID. The GUI object must have been previously added with AddCustomGui()"
This means that it is not possible to get the value of a LINK gizmo that is defined by a res file?
On 02/08/2016 at 14:30, xxxxxxxx wrote:
mylink = self.FindCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX) if mylink.GetLink().GetType() != None: print mylink.GetLink().GetName() #<--The name of the object in the linkbox gizmo
On 02/08/2016 at 15:06, xxxxxxxx wrote:
Aha!!! My mistake was that I was doing:
mylink = self.FindCustomGui(MY_LINKBOX, MY_PLUGIN_ID)
But it was...
THANK YOU!!!
