On 24/07/2016 at 11:47, xxxxxxxx wrote:
I was trying to create a simple CommandData plugin. However, I need a Link field in the dialog and I don't have that type of gizmo in the GeDialog to add to the dialog. So, I was trying to make the dialog through a resource file, as those have the LINK gizmo. The problem is that the only examples that are provided with the SDK are for CommandData plugins that create a dialog though code. A working example for a CommandData plugin that would work with a dialog resource would be great. Can anyone help out on this one?
On 24/07/2016 at 12:34, xxxxxxxx wrote:
I have an example called "Dialog Using Resources" on my website: https://sites.google.com/site/scottayersmedia/plugins
Is that what you want?
On 24/07/2016 at 15:31, xxxxxxxx wrote:
YES! That is it Thank you, Scott.
On 25/07/2016 at 00:57, xxxxxxxx wrote:
a "link field" is no standard GUI element but a custom GUI element. So you can add a LinkBoxGui to your dialog using AddCustomGui().
Best wishes, Sebastian
On 25/07/2016 at 02:56, xxxxxxxx wrote:
Great to know that, Sebastian. I usually prefer to have dialogs/interfaces defined with resources, as it is easier to adjust and can deal with multiple languages. But, sometimes, I need to create dynamic, self adjustable interfaces and in that case, I need to do it using code. So, that is of great help.
