On 26/05/2016 at 11:17, xxxxxxxx wrote:
Hello programmers!
Hello from italy, i have a little problem my script play with object point and work well but... dosen't work afther the random modifier in point mode, there is a command to get the point position afther random play?
On 27/05/2016 at 01:52, xxxxxxxx wrote:
I guess you use a MoGraph Random modifier as a deformer in point mode? You can access the deformed state of an object by accessing the deformed cache with GetDeformCache().
Best wishes, Sebastian
On 31/05/2016 at 02:31, xxxxxxxx wrote:
perfect, this is the correct way to do this!
