On 12/05/2016 at 07:26, xxxxxxxx wrote:
I have a ObjectData plugin and thus a description "dialog". I am using a resouce file to define the description.
I like to center a button, but i do not know how to do this.
CONTAINER descriptionTest { INCLUDE Obase; GROUP OTEST { BUTTON OB_FIT {} //How to center this button? ......
On 13/05/2016 at 02:35, xxxxxxxx wrote:
a parameter description is not a dialog. It is primarily just a list of parameters. It may be displayed in the Attribute Manager or in a different context. So the possibilities for layout the parameters are limited.
Parameters are organized in groups. So a parameter is typically not centered or placed directly. Instead the parent group or groups are defined. Some complex example can be found in the resource file of the cloth tag.
I tried to come up with some centered button but did not succeed. So I cannot really say if it is possible to archive this specific layout with the limited possibilities of the parameter description.
Best wishes, Sebastian
On 13/05/2016 at 09:19, xxxxxxxx wrote:
Ok, thanks. I understand and leave it as it is.
-Pim
