On 15/01/2003 at 16:19, xxxxxxxx wrote:
User Information: Cinema 4D Version: 8.012 Platform: Windows ; Language(s) : C.O.F.F.E.E ;
--------- Hello! I´m trying to adjust a polygon of an object to a polygon of another object. For this I have to rotate one of the objects. I have calculated the normals of this polys and with VectorToHPB the corresponding angles. Unfortunately my math isn´t good enough to know what to do with this angles to get the rotation of the object right. Taking the difference doesn´t quite work. I think I should use this difference to calculate new HPB angles. But how is this done? Thanks in advance
On 16/01/2003 at 17:48, xxxxxxxx wrote:
The resulting rotation isn't uniquely defined, since you could always add a bank along the parallel normals. I think the easiest way to get a solution is to first calculate the cross product of the normals (to get the rotation axis), then take the arc-sine of the length of the axis (to get the angle between the normals) and finally use Matrix::SetRotAxis() to get a transformation matrix: (Untested code.)
var obj1 = ...; var obj2 = ...; var normal1 = ...; var normal2 = ...; var axis = vcross(normal1, normal2); var angle = asin(vlen(axis)); var mat = new(Matrix); mat->SetRotAxis(axis, angle); obj2->SetMg(mat->GetMulM(obj->GetMg()));
On 19/01/2003 at 16:18, xxxxxxxx wrote:
Thanks alot. That did it.
