save previous position of an object
On 21/04/2016 at 09:11, xxxxxxxx wrote:
i want to save the position of many objects animated by an dynamic tag to calculate the velocity per frame for it
script tag is set to frame depending
poly_arr_old = []
def main() :
    global poly_arr_old
    poly = op.GetObject().GetDown()
    #poly_arr_new from objects
    poly_arr_new = []
    while poly:
        poly_arr_new.append(poly)
        poly = poly.GetNext()
    if (len(poly_arr_old) == len(poly_arr_new)) :
        for i in range(0,len(poly_arr_new)) :
            #compare
            print (poly_arr_old[i].GetMg().off - poly_arr_new[i].GetMg().off).GetLength()
    # flush old list and create a COPY from poly_arr_new
    poly_arr_old = []
    for item in poly_arr_new:
        poly_arr_old.append(item)
    print "#" * 64
    pass  #put in your code here
On 21/04/2016 at 10:40, xxxxxxxx wrote:
What is your question?
On 22/04/2016 at 01:30, xxxxxxxx wrote:
as Nikals said, can you specify your question?
What exactly do you mean with "script tag"? I guess you mean a Python Tag? If you want to store data consistently across time you could store data for example in the BaseContainer of the tag itself.
Best wishes,
Sebastian
On 22/04/2016 at 04:06, xxxxxxxx wrote:
it seems to work fine but the previous and current frame data are still the same
def main() :
    bc = op.GetDataInstance()
    frame=doc.GetTime().GetFrame(doc.GetFps())
    poly_arr_new = []
    while poly:
    if bc.GetData(frame+10000-1) != None:
        poly_arr_old = bc.GetData(frame+10000-1)
            print poly_arr_old[i].GetMg().off
            print poly_arr_new[i].GetMg().off
    poly_arr_old = c4d.BaseContainer()
    i = 0
        poly_arr_old.SetData(i,item)
        i +=1
    bc.SetData(frame+10000,poly_arr_old)
    print "#" * 64
On 22/04/2016 at 11:30, xxxxxxxx wrote:
I think you need to store the *positions* in the old and new arrays, not the objects : )  For example, instead of poly_arr_new.append(poly) you might have pos_array_new.append(poly.GetMg().off).
