On 06/04/2016 at 17:54, xxxxxxxx wrote:
I seem to be having a hard time understanding why this line is here.
import c4d def main() : doc = c4d.document.GetActiveDocument() print doc if __name__ == "__main__": main()
I understand that this quick sample will execute the main() function. What's the difference then if the code does this?
import c4d if __name__ == "__main__": doc = c4d.documents.GetActiveDocument() print doc
Obviously it's not going to run a main() function because now it doesn't exist. You get the same result though.
Is one way preferred over another? What would be the reason to use one over the other?
I feel like I'm mostly confident in programming but this seems like a glaring oversight in fundamentals on my part as to why I don't understand this.
On 07/04/2016 at 02:06, xxxxxxxx wrote:
the line " if __name__ == "__main__"" is a typical Python idiom. It is used to distinct between loading the code (in a module) and executing the code.
Using a main() function makes no different but like any other pattern it is useful to organize the code.
See also
if \__name\_\_ == "\__main\_\_":
best wishes, Sebastian
On 15/04/2016 at 09:12, xxxxxxxx wrote:
Hello Herbie,
was your question answered?
Best wishes, Sebastian
