On 05/04/2016 at 04:44, xxxxxxxx wrote:
User Information: Cinema 4D Version: 15-17 Platform: Windows ; Language(s) : C++ ;
--------- Hi,
when compiling any R15 project including the SDK with VS2013 I get warning C4005 in allmost all files:
1>c:\program files\maxon\cinema 4d r15\resource\_api\c4d_misc\utilities\compilerdetection.h(61) : warning C4005: '_HAS_DECLTYPE': macro redefinition (..\_api\c4d_basebitmap.cpp) 1> c:\program files (x86)\microsoft visual studio 12.0\vc\include\yvals.h(15) : see previous definition of '_HAS_DECLTYPE'
Just these warnings. It builds the project fine and I can't encounter any problems when running.
Is it safe to just switch off the redefinition in the compilerdetection.h file using #ifndef ?
EDIT: Setting the warning level from 4 to 3 has no effect.
On 06/04/2016 at 09:11, xxxxxxxx wrote:
Hi Klaus,
I'm sorry, we only support the IDE versions stated for every SDK. And we also can't recommend changes to the Cinema framework sources. With such changes you are on your own. Sorry!
On 14/04/2016 at 00:25, xxxxxxxx wrote:
As for the warning: Just add them as ignore in project settings. This happens when using a newer compiler as the one that the SDK is built for. (VS2010(v100) > VS2013(v120) platform tools, for example)
