ObjectPlugin - Attributes
On 30/03/2016 at 13:24, xxxxxxxx wrote:
Hey guys,
so I am working on a Object Plugin for particles.
My problem is (and I had this problem in some other plugins before) that as soon as I "create" a second attribute for my Object like in the picture below the Bitmapbutton, I always get this error message:
AttributeError: 'module' object has no attribute 'dev_header'
and I don't know how to get rid of it, since I already have an attribute (which is functioning) in my object.Picture: http://prntscr.com/am6b95
I really don't know how to solve this problem,
I hope someone can help me out with that.Thanks in advance,
neon
On 31/03/2016 at 08:23, xxxxxxxx wrote:
Hi neon,
there seems to be an issue with the symbol cache.
Please try the following:
Go to your user's Cinema 4D home directory (a quick way from within Cinema: open the preferences and click the "Open Preferences Folder..." button in the lower left). In there you will find a "prefs" folder. In this prefs folder you'll find a file called "symbolcache". Delete this file and start Cinema. The symbol cache will be rebuilt and your problem is hopefully solved.
On 31/03/2016 at 09:06, xxxxxxxx wrote:
Hello Andreas,
Thanks for your help, it worked!
I really had this problem for quite a while now, and I always thought I messed something up in my code.Just one litle question: is there some way I can prevent this error happening?
greetings,
neon
