SplineData: Sort knots by x-value
On 25/03/2016 at 12:31, xxxxxxxx wrote:
Hello everybody,
I´d like to imitate the behavior of SplineData by manually changing x-values of knots with python. Meaning, if I pick up a knot by hand and drag it over/under the x-value of another knot, the line of spline will be set well from one to the other knot. If I use python the line will be broken.
spl = op[c4d.ID_USERDATA,1] spl.SetKnot(0, c4d.Vector(0.5,0,0)) op[c4d.ID_USERDATA,1] = spl
I already tried to sort the list of splinedata.GetKnots() by knots["vPos"].x ...
for i, knot in enumerate(sorted(op[id].GetKnots(), key=lambda k: k['vPos'].x)) : spl.SetKnot(index=i, vPos=knot["vPos"], lFlagsSettings=knot["lFlagsSettings"], bSelect=knot["bSelect"], vTangentLeft=knot["vTangentLeft"], vTangentRight=knot["vTangentRight"], interpol=knot["interpol"])
... but the result is equal
SplineData.SortKnots
() and so not what I´m looking for.Finally I´ve found the following note in the SDK >
Note
Also contains the point index ID. The ID can be accessed using these functions:def SplineKnotGetID(flags) :
return ((flags >> 16) & 0x0000ffff)def SplineKnotSetID(flags, flag_id) :
flags = (flags & 65535) | ((flag_id & 0x0000ffff) << 16)Important
This means that the flags must only be accessed using '|=' and ' &=' (a good advice for any set of flags, for maximum forward compatibility).... but I really don´t know how to use this function rigth.
Does anyone knows a solution?
Thx and greetings
rownn
On 28/03/2016 at 02:18, xxxxxxxx wrote:
Have you tried to swap the active and next knots? The spline shouldn't brake.
Don't worry about the spline knot ID. This is set at the creation of a knot. To add a knot to the spline use SplineData.InsertKnot().
In your case you don't need to create a new knot, just swap 2 existing ones.
