On 20/03/2016 at 11:50, xxxxxxxx wrote:
User Information: Cinema 4D Version: 17 Platform: Windows ; Language(s) : PYTHON ;
--------- Hi, guys! How to get Multipass selected in Render Settings? i try this code, but it don't works. What's wrong?
import c4d def main() : rd = doc.GetActiveRenderData() vp = rd.GetFirstMultipass() while vp: if vp.GetTypeName() == 'Object Buffer' and vp.GetBit(c4d.BIT_ACTIVE) : print vp.GetName() vp = vp.GetNext() if __name__=='__main__': main()
On 20/03/2016 at 18:14, xxxxxxxx wrote:
Have you simply checked to see if vp.GetBit(c4d.BIT_ACTIVE) works (without name checking)? If not, it is possible that this state is not set for MultipassObjects.
On 21/03/2016 at 06:33, xxxxxxxx wrote:
the bit you are looking for is actually BIT_VPDISABLED instead of BIT_ACTIVE. Also note the inverted logic of that bit (true means "not enabled").
Hope you don't mind, I have moved the thread into the Python subforum.
On 24/03/2016 at 15:25, xxxxxxxx wrote:
Thanks, guys!
