On 17/03/2016 at 03:23, xxxxxxxx wrote:
how do i calculate the correct matrixes for a geraycollide to get the option to move the target and the source? all i see is that geraycollide works with local matrixes and i presume that i need to calculate a global matrix for it. but i don't know how
import c4d from c4d.modules import mograph as mo from c4d.utils import GeRayCollider #Welcome to the world of Python def main() : md = mo.GeGetMoData(op) if md is None: return False cnt = md.GetCount() marr = md.GetArray(c4d.MODATA_MATRIX) fall = md.GetFalloffs() ray = GeRayCollider() UsrDtColl = op[c4d.ID_USERDATA,1] ray.Init(UsrDtColl, True) ml = gen.GetMl() mg = gen.GetMg() img = ~mg for i in reversed(xrange(0, cnt)) : if ray.Intersect(marr[i].off+img.off,marr[i].off+img.off, 300) == True: marr[i].off = ray.GetNearestIntersection()["hitpos"] md.SetArray(c4d.MODATA_MATRIX, marr, True) return True
On 17/03/2016 at 16:12, xxxxxxxx wrote:
status update:
now i can move the source point of the GeRayCollide, rotate won't work atm. next step is to make the collider moveable too.
current file:
http://postwendend.com/frei/ray2.c4d
On 18/03/2016 at 03:16, xxxxxxxx wrote:
The explanation and script source code in the following post should help you: https://plugincafe.maxon.net/topic/8840/11677_problem-with-geraycollider-solved&PID=46053#46053
