On 16/03/2016 at 02:53, xxxxxxxx wrote:
Hi!
I'm creating a very simple plug-in that does the following:
1. Creates a window/dialog with 4 file URL fields (text field + button) and import button. 2. The user selects 4 .c4d files from the /res folder 3. The user hits the import button and the script merges the .c4d files into the current document.
I come from Maya/Python programming, but I'm very new to C4D/Python. I check the C++ and Py docs before asking as well.
Question #01: What do I pass this command? c4d.documents.MergeDocument(doc, name, loadflags[, thread])
What do I pass to "doc"? I keep my plug-in in the Library->Pref->etc. folder on OSX. How do I get that URL and pass it to "name"?
I've seen a couple scripts that kind of do this but hopefully after I figure out this simple bit I'll be able to hack away at the rest.
Thank you for your time.
Matt
On 16/03/2016 at 14:02, xxxxxxxx wrote:
Hi Matt and welcome.
It refers to the active document doc = c4d.documents.GetActiveDocument()
-b
Active document GetActiveDocument()
Prefs directory c4d.storage.GeGetC4DPath(whichpath)
On 17/03/2016 at 09:58, xxxxxxxx wrote:
Hey,
Thanks for the response, that worked great and I figured out how to find the /ref folder using the OS module.
I have another questions regarding the UI. How would I go about creating images with text next to them, like the Content Browser? I'd like to write my own custom version of that, but I don't see a way of adding images.
Thanks!
On 17/03/2016 at 14:50, xxxxxxxx wrote:
I've never made UI with bitmaps before but i think this might be what you're looking for: GeUserArea.DrawBitMap()
On 18/03/2016 at 01:49, xxxxxxxx wrote:
As Bonsak already suggested, you can create your own GeUserArea. Probably the most versatile approach in Python. A much simpler option would be to use a CustomGUI BitmapButton for the image (turn off button behavior with BITMAPBUTTON_BUTTON) and have the text as static text. Depends on your needs and the style you want to achieve, what works best for you.
On 20/03/2016 at 18:11, xxxxxxxx wrote:
Thank you both for the response. I tried the Bitmap Button and it works pretty well. I'm going to do more research into the User Area, that looks promising.
