On 07/03/2016 at 18:19, xxxxxxxx wrote:
--------- Hi folks,
are the icons native to C4D available for use across all versions (i.e. Prime-to-Studio)? I know the plugins themselves aren't, but are the icons?
WP.
On 08/03/2016 at 01:20, xxxxxxxx wrote:
when you register a plugin you use a function like RegisterObjectPlugin(). This function also defines the icon of the registered plugin. So if a plugin is not registered at all, also its icon is not registered and available.
Other icons defined in Cinema's core might be available in all versions.
Best wishes, Sebastian
On 08/03/2016 at 06:24, xxxxxxxx wrote:
But I think all of these are available in all versions:
https://developers.maxon.net/docs/Cinema4DPythonSDK/html/modules/c4d.bitmaps/RESOURCEIMAGE.html
On 08/03/2016 at 07:25, xxxxxxxx wrote:
The icons are available in a TIF image with reference text in modules/c4dplugin/icons while some other images are in modules/c4dplugin/bmp. Icon images for specific modules reside in their specific module folder.
As Sebastian notes, availability may be ubiquitous or they may only be registered as icons dependent upon version.
On 09/03/2016 at 19:46, xxxxxxxx wrote:
Niklas - a handy list to have there, bookmarked!
Saves a bit of effort if there's already one available for use, keeps things consistent. In a way it's a small pity all icons aren't available across the board, but probably fair enough. Thanks Folk!
