On 07/03/2016 at 01:55, xxxxxxxx wrote:
User Information: Cinema 4D Version: R17 Platform: Windows ; Language(s) : C++ ;
--------- Hello.
I have my own renderer and whenever i have to render a C4D document for a specific frame (lets say frame 20), I use doc->ExecutePasses(thread, TRUE, TRUE, TRUE, BUILDFLAGS_EXTERNALRENDERER) to calculate the animation. The variables doc and thread are taken from VideoPostStruct parameter of VideoPost's Execute method.
I have an effect that requires the object global matrices of future frames.
So whenever I have to pass any object's matrix in my renderer, i do the following as well:
BaseTime original_time = doc->GetTime(); Int32 fps = doc->GetFps(); doc->SetTime(BaseTime(future_frame , fps)); //set future frame doc->ExecutePasses(threa, TRUE, TRUE, TRUE, BUILDFLAGS_EXTERNALRENDERER); Matrix object_matrix = object.GetMg(); doc->SetTime(original_time); //revert frame doc->ExecutePasses(NULL, TRUE, TRUE, TRUE, BUILDFLAGS_EXTERNALRENDERER);
Is this the correct way to get the required global matrix from an object in specific future frame ?
If I have hair in my scene, I execute passes for every frame from 0 to future_frame.
Thank you for your time.
On 08/03/2016 at 01:47, xxxxxxxx wrote:
I don't think there is a "correct" or "official" way of handling this situation. The most correct solution would be to wait for the next frame and to get the matrix of the object then.
I would strongly disadvise to manipulate the given BaseDocument this way. Depending on what you do elsewhere of what other post effects might be added, changing the BaseDocument this way could cause problems. It would be saver to do such operations (animation) on a copy of the given BaseDocument.
If you work on a copy of the BaseDocument you might not need to rewind it (depending on how you work with it). If you rewind it, you also might rewind it if the document contains particles, thinking paticles or dynamics.
Best wishes, Sebastian
On 08/03/2016 at 05:36, xxxxxxxx wrote:
Hello.
Thank you for your response. Indeed I use a copy of the document. I set the time of the document only for the purposes of global matrix retrieval. Then i set it back in the original time in order to be used by the rest of the objects.
Thank you.
On 15/03/2016 at 02:02, xxxxxxxx wrote:
By setting the doc's time to a future time I can get the future position of an object. But, there is a problem if the object stops existing in the future (in case it is generated by a cloner).
Considering I have a BaseObject pointer retrieved in frame 30, how can I check if this object is still valid in frame 60 ? I have used SetFrame and ExecutePasses on the document. By getting its matrix via object.GetMg() I get a crash, because the object doesn't exist in that frame.
How can I make a check if the object exists ?
On 15/03/2016 at 10:16, xxxxxxxx wrote:
you should not store a pointer to any Cinema 4D scene element as a reference. To store a reference to an entity use a BaseLink object. That said, this might not work for virtual objects created by a generator since the generator may re-create the object at any time.
A generator that creates multiple virtual objects should set a unique IP for each of these objects (see BaseObject::GetUniqueIP()). So you can try to use this IP to search for a specific object in a generator's cache at a certain time.
On 18/03/2016 at 01:32, xxxxxxxx wrote:
Hello
Originally posted by xxxxxxxx That said, this might not work for virtual objects created by a generator since the generator may re-create the object at any time.
Is this going to be a problem even if the generator (or emitter) has been baked ?
Originally posted by xxxxxxxx A generator that creates multiple virtual objects should set a unique IP for each of these objects (see BaseObject::GetUniqueIP()). So you can try to use this IP to search for a specific object in a generator's cache at a certain time.
I use the GetUniqueIP but even if the object shouldn't exist, it still returns its initial IP value.
On 18/03/2016 at 08:28, xxxxxxxx wrote:
Originally posted by xxxxxxxx I use the GetUniqueIP but even if the object shouldn't exist, it still returns its initial IP value.
Allow me to correct this statement. Considering that I have an emitter that generates 3 objects with lifetime 40 frames, whenever an object reaches the end of its lifetime, ALL objects change UniqueIP, even if they will not die for the rest of the track.
So, even though the BaseLink solution you mentioned before helps me to preserve the object, I cannot find a way to ensure that it has not passed its lifetime.
The best solution for me would be that the particle objects don't modify their unique IPs until the end of their lifetime. Is there any way to do that ?
On 21/03/2016 at 04:45, xxxxxxxx wrote:
are you talking about the standard particle emitter? I don't seem to have a problem with the unique IP of the cache objects. This is what I try:
BaseObject* op = doc->GetActiveObject(); if (!op || !op->IsInstanceOf(Oparticle)) return false; BaseObject* cache = op->GetCache(); if(cache && cache->GetDown()) { BaseObject* particle = cache->GetDown(); while(particle) { GePrint("Unique IP: " + String::IntToString(particle->GetUniqueIP())); particle = particle->GetNext(); } }
best wishes, Sebastian
