On 04/03/2016 at 04:37, xxxxxxxx wrote:
User Information: Cinema 4D Version: R17 Platform: Windows ; Language(s) : C++ ;
--------- Hello.
Which is the best way to get the time of a specific frame (not current) in document ? BaseDocument's GetTime returns the time of current time. I need to give the frame as parameter and get the time in the same document.
Thank you.
On 04/03/2016 at 06:16, xxxxxxxx wrote:
It would seem that if you get the frames-per-second (FPS) from the document it is simply a matter of setting time = frame / document->GetFps(). So you could call BaseTime setting the numerator (frame) and the FPS (denominator) separately. or simpler yet is to construct the BaseTime using the constructor:
BaseTime frameTime = BaseTime(frame, fps);
This sets both the numerator to the frame value and the denominator to the frames-per-second value. This is why you really don't need a method in BaseDocument that gets the time of the frame (but you do need a method that gets the frame at a time because of the internal storage of time in BaseTime).
