On 26/02/2016 at 01:25, xxxxxxxx wrote:
Hello! Quick question: Why does setting the parameter c4d.BASEDRAW_DATA_ROTATION_CIRCLE = 123 have no effect?
That's the param holding the Axis' size. (VP menu > Options > Configure All, Attribute Editor Tab View > Axes Scale
Thanks!! Best regards Eugen
On 29/02/2016 at 07:52, xxxxxxxx wrote:
do you have that line in your code?
then it's no wonder it has no effect, because you are writing over the ID, which you should actually use to address the BaseContainer. You will rather want to use something like this:
bd[c4d.BASEDRAW_DATA_ROTATION_CIRCLE] = 123
On 01/03/2016 at 04:26, xxxxxxxx wrote:
Oops, I see! Yes, I'm a freshie when it comes to C4D scripting... Thanks, Andreas!! Best regards Eugen
On 01/03/2016 at 05:50, xxxxxxxx wrote:
Here's the script I needed this for: 'ToggleAxis' Purpose: Since C4D does not display some other kind of axis icon when in axis mode, it's very easy to overlook that you ARE in axis mode! You have no idea how often I stumbled across this... I put this script on some keyshort, and always use it to toggle axis mode. It also turns on snapping, and reduces the SIZE of the axis (and back).
import c4d from c4d import gui from c4d.modules import snap
def main() : bd = doc.GetActiveBaseDraw()
if(not doc[c4d.DOCUMENT_AXIS]) : snap.EnableSnap(True, doc) c4d.CallCommand(c4d.ID_MODELING_MOVE) # Enable Move Tool bd[c4d.BASEDRAW_DATA_OBJECTAXIS_SCALE] = 0.2 #bd: BaseDraw doc[c4d.DOCUMENT_AXIS] = True else: bd[c4d.BASEDRAW_DATA_OBJECTAXIS_SCALE] = 0.5 doc[c4d.DOCUMENT_AXIS] = False c4d.EventAdd()
if __name__=='__main__': main()
