Set starting folder [SOLVED]
  • On 21/02/2016 at 03:22, xxxxxxxx wrote:
    I know two ways to search for a folder, but I do not how to set the folder where to start the search.
    For example, search for a folder in c:/temp?
    Both ways do not start with c:/temp
        path = c4d.storage.LoadDialog(c4d.FILESELECTTYPE_ANYTHING,
            "Please choose a folder", c4d.FILESELECT_DIRECTORY, "", "c:/temp")
            settings = c4d.BaseContainer()
            settings.SetBool(c4d.FILENAME_DIRECTORY, True);
            self._filename = self.AddCustomGui(10112, c4d.CUSTOMGUI_FILENAME, "", c4d.BFH_SCALEFIT, 50, 10, settings)
            self.SetString(10112, "C:/temp/")
  • On 21/02/2016 at 07:06, xxxxxxxx wrote:
    Windows and Macs use different escapes (\\ vs. /) which can easily cause problems.
    Try it like this:
    def main() :
          "Please choose a folder", c4d.FILESELECT_DIRECTORY, "", "c:\\temp")
    if __name__=='__main__':
  • On 21/02/2016 at 11:24, xxxxxxxx wrote:
    Yes, I learned that the hard way.
    Unfortunately that is not the solution.
    The search does with "c:\ emp" or "c:/temp".
    I even tried "c:/temp/"
    Thanks, Pim
  • On 21/02/2016 at 12:57, xxxxxxxx wrote:
    That's strange.
    The code I posted opens a file browser with the C: emp folder selected
    I'm using R13. Maybe something has changed?
  • On 22/02/2016 at 00:31, xxxxxxxx wrote:
    Sorry,you are correct, c:\ emp is selected, but not as the top one.
    I see a huge folder tree and then scrolling done I see c:\ emp is indeed selected.
    I would like cinema to scroll down and show the selected folder on top.
    Also the folder is only selected, not opened.
    -Pim
