On 10/02/2016 at 04:57, xxxxxxxx wrote:
User Information: Cinema 4D Version: R17 Platform: Language(s) : C++ ;
--------- Here is the newbie again, I've managed to create my object derived from ObjectData but what if I want to move it from inside itself?
Moving it seems to be trivial using BaseObject* functions but I cannot find the way to get it.
Regards and thank you in advance again!
On 10/02/2016 at 05:38, xxxxxxxx wrote:
From inside your ObjectData-derived class, you can use either the GeListNode* node passed to the method in the class:
//*---------------------------------------------------------------------------* Bool MyObjectData::Message(GeListNode* node, Int32 type, void* data) //*---------------------------------------------------------------------------* { if (!node) return FALSE; BaseObject* pObject = static_cast<BaseObject*>(node); // etc. return SUPER::Message(node,type,data); }
Or you can use the NodeData::Get() method:
//*---------------------------------------------------------------------------* Bool MyObjectData::MyMethod() //*---------------------------------------------------------------------------* { GeListNode* node = Get(); if (!node) return FALSE; BaseObject* pObject = static_cast<BaseObject*>(node); // etc. return TRUE; }
On 10/02/2016 at 10:02, xxxxxxxx wrote:
Thank you second method is perfect for me
