On 02/02/2016 at 08:56, xxxxxxxx wrote:
I have a plugin that is, fundamentally, working. However, when I run it several times, sometimes it hangs (and creates a bugreport warning).
I don't know if I'm leaving something behind that is not freed correctly or what else could be causing this.
My plugin is as follows (and includes) :
- A modal dialog. Yes, I want it to be modal. I have to make sure that, when it is running, absolutely no changes can occur in the document.
- The model dialog includes a User Area.
- The User Area is refreshed by a Timer from the dialog.
- A button in the dialog triggers a User Thread that performs a cycle. Inside that cycle, I render several frames, using c4d.documents.RenderDocument
- Another button allows the abortion of the render. This is done through a global variable that is set to True if the Abort is pressed. And the rende(c4d.documents.RenderDocument) only occurs if the global variable is False.
Is there any type of garbage collection that can/should be performed? I know it should occur automatically when my plugin finishes (closes). But, sometimes, I perform several calculations and abort those calculations before closing the window, and it hangs.
Sometimes, I close the plugin and, when I open it again, it hangs when I start the calculation.
What could possibly be wrong for it to hang sometimes and others don't?
On 03/02/2016 at 03:02, xxxxxxxx wrote:
Hi Rui,
Without any code it's difficult to tell what's wrong. But it looks like this is related to how the thread is managed. How is it started/stopped? Are you sure nothing forbidden is done inside it?
Please post some code for these parts.
On 04/02/2016 at 04:25, xxxxxxxx wrote:
Thank you, Yannick. I will prepare a listing of the snippets of relevant code, stripping out the junk and commenting as much as I can.
On 04/02/2016 at 04:48, xxxxxxxx wrote:
""" Diffence Render Written for Cinema 4D R15 and up """ import c4d from c4d import gui, plugins, utils, bitmaps, storage from c4d.threading import C4DThread from datetime import datetime import time import os v_start_frame=2000 v_end_frame=2001 b_close=2010 b_calculate=2011 b_copy_rs=2012 quality=2020 the_filename=2030 b_filename=2040 b_abort=2050 t_info=2060 t_info2=2070 #be sure to use a unique ID obtained from www.plugincafe.com PLUGIN_ID = 1036575 rImage1 = bitmaps.BaseBitmap() rImage2 = bitmaps.BaseBitmap() mImage = bitmaps.BaseBitmap() start_frame=0 end_frame=99 current_frame=99 abort = False calculating = False document_time = c4d.BaseTime() start_time = time.time() last_estimate = 0 last_estimate_string = "" frames_dir = "" masks_dir = "" main_dir = "" average_change = 0 # ******************************************************************************* class RenderDisplay(gui.GeUserArea) : highlight_line = c4d.Vector(0, 0.6, 0) black = c4d.Vector(0) white = c4d.Vector(1) shadow_line = c4d.Vector(0.15) success = False def __init__(self,bmp) : super(RenderDisplay, self).__init__() self.bmp = rImage1 def DrawMsg(self, x1, y1, x2, y2, msg_ref) : global start_frame global end_frame global current_frame global abort global calculating #init draw region self.OffScreenOn() self.SetClippingRegion(x1, y1, x2, y2) the_color=self.GetColorRGB(c4d.COLOR_BG) back_color=c4d.Vector(the_color['r']/255.0,the_color['g']/255.0,the_color['b']/255.0) dimmed=c4d.Vector(c4d.utils.Clamp(0.0,1.0,back_color.x*1.1),c4d.utils.Clamp(0.0,1.0,back_color.y*1.1),c4d.utils.Clamp(0.0,1.0,back_color.z*1.1)) self.DrawSetPen(back_color) self.DrawRectangle(x1, y1, x2, y2) self.DrawBorder(c4d.BORDER_THIN_IN,0,0,256,256) self.DrawBorder(c4d.BORDER_THIN_IN,272,0,528,256) if self.bmp: ww=self.bmp.GetBw() hh=self.bmp.GetBh() if ww>0 and hh>0: sc=254.0/float(ww) if hh*sc>254: sc=254.0/float(hh) nw=int(ww*sc) nh=int(hh*sc) nx=128-int(nw/2) ny=128-int(nh/2) self.DrawBitmap(self.bmp,nx,ny,nw,nh,0,0,ww,hh,c4d.BMP_NORMAL) if mImage: self.DrawBitmap(mImage,270+nx,ny,nw,nh,0,0,ww,hh,c4d.BMP_NORMAL) # progress bar self.DrawBorder(c4d.BORDER_THIN_IN,100,268,528,278) self.DrawSetPen(self.white if calculating else dimmed) percent=0.0 progress="Frame --/--" if float(end_frame-start_frame)>0.0: percent=float(current_frame-start_frame+1)/float(end_frame-start_frame+1) self.DrawRectangle(102, 270, int(102+424*percent), 276) #self.DrawSetTextCol(self.white, back_color) self.DrawSetTextCol(self.white if calculating else dimmed, back_color) progress="Frame "+str(int(current_frame-start_frame+1))+"/"+str(int(end_frame-start_frame)+1) self.DrawText(progress if calculating else "Frame --/--", 2, 266) # ******************************************************************************* class MyThread(c4d.threading.C4DThread) : thumbnail = RenderDisplay(None) v_quality=0 def Main(self) : global start_frame global end_frame global current_frame global abort global calculating global frames_dir global masks_dir global start_time global main_dir global average_change # not calculating at the moment... if calculating==False: return # get the render data doc=c4d.documents.GetActiveDocument() rd=doc.GetActiveRenderData() # bitmap size o_ww=rd[c4d.RDATA_XRES] o_hh=rd[c4d.RDATA_YRES] ww=int(o_ww*self.v_quality) hh=int(o_hh*self.v_quality) # get the content of the render data container new_rd=doc.GetActiveRenderData().GetData() new_rd[c4d.RDATA_MULTIPASS_ENABLE] = False new_rd[c4d.RDATA_PROJECTFILE] = False new_rd[c4d.RDATA_FRAMESEQUENCE] = 1 new_rd[c4d.RDATA_SAVEIMAGE] = False new_rd[c4d.RDATA_MULTIPASS_SAVEIMAGE] = False new_rd[c4d.RDATA_XRES]=ww new_rd[c4d.RDATA_YRES]=hh new_rd[c4d.RDATA_ANTIALIASING] = 0 # no antialiasing rImage1.Init(ww,hh,24) rImage2.Init(ww,hh,24) mImage.Init(ww,hh,24) # perform the renders while not aborting and before the end of all frames while current_frame<=end_frame and abort==False and calculating==True: new_rd[c4d.RDATA_FRAMEFROM]=c4d.BaseTime(current_frame,doc.GetFps()) new_rd[c4d.RDATA_FRAMETO]=c4d.BaseTime(current_frame,doc.GetFps()) doc.SetTime(c4d.BaseTime(current_frame,doc.GetFps())) res2=c4d.documents.RenderDocument(doc,new_rd,rImage1,c4d.RENDERFLAGS_EXTERNAL|c4d.RENDERFLAGS_NODOCUMENTCLONE) # prepare the mask if current_frame==start_frame: # first frame for yy in xrange(hh) : for xx in xrange(ww) : mImage.SetPixel(xx,yy,255,255,255) else: for yy in xrange(hh) : for xx in xrange(ww) : diff= 0 if rImage1.GetPixel(xx,yy)==rImage2.GetPixel(xx,yy) else 255 mImage.SetPixel(xx,yy,diff,diff,diff) # save the frame and the mask frame_name=os.path.join(frames_dir,"frame_%05d.png" % (current_frame,)) result=rImage1.Save(frame_name,c4d.FILTER_PNG) masks_name=os.path.join(masks_dir,"mask_%05d.png" % (current_frame,)) result=mImage.Save(masks_name,c4d.FILTER_PNG) rImage1.CopyTo(rImage2) current_frame=current_frame+1 # RENDER FINISHED!!! # create a report file if os.path.exists(main_dir) : report_path=os.path.join(main_dir,"Report.txt") hf=open(report_path,'w') if hf: hf.write("Report for file < "+doc.GetDocumentName()+" >\n\n") hf.write("Date: "+time.strftime("%d/%m/%Y")+"\n\n") hf.write("Original frame size: %d x %d\n" % (o_ww,o_hh)) hf.write("Final masks frame size: %d x %d\n\n" % (ww,hh)) hf.write("Frame Range: frame %d to frame %d (%d in total)\n\n" % (start_frame,end_frame,end_frame-start_frame+1)) if abort: hf.write("ABORTED BEFORE COMPLETION AT FRAME "+str(current_frame)+"!\n\n") spent=time.time()-start_time d=divmod(spent,86400) h=divmod(d[1],3600) m=divmod(h[1],60) s=m[1] hf.write("Total render calculation time: %02d:%02d:%02d\n\n" % (h[0],m[0],s)) total_pixels=(end_frame-start_frame+1)*(ww*hh) aver=float(total_pixels-average_change)/float(total_pixels) hf.write("Average change: %d%% (less change is better)" % (100*(1.0-aver),)) hf.close() # clean the house rImage1.FlushAll() rImage2.FlushAll() mImage.FlushAll() abort=True calculating=False # ******************************************************************************* class DiffRender(gui.GeDialog) : thumbnail = RenderDisplay(None) thread = MyThread() counter=0 def CreateLayout(self) : self.SetTitle("Render Differences") self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT, title="", rows=1, cols=1, groupflags=c4d.BORDER_GROUP_IN) self.GroupBorderSpace(5, 5, 5, 5) #give really unique ID to userarea, otherwise the update process will fail! area = self.AddUserArea(id=1001, flags=c4d.BFH_SCALEFIT|c4d.BFV_TOP,initw=528, inith=204) self.AttachUserArea(self.thumbnail, area) self.AddStaticText(id=t_info2,flags=c4d.BFH_SCALEFIT|c4d.BFV_TOP,inith=0, name="Info: ---", borderstyle=c4d.BORDER_THIN_IN) self.AddButton(id=b_abort, flags=c4d.BFH_CENTER,initw=64, inith=16, name="Abort") self.AddSeparatorH(inith=0, flags=c4d.BFH_FIT) # Filename self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT|c4d.BFV_TOP, title="", rows=1, cols=3,) self.AddStaticText(0,flags=c4d.BFH_LEFT|c4d.BFV_TOP,initw=90, inith=12, name="Masks Path") self.AddEditText(id=the_filename,flags=c4d.BFH_SCALEFIT|c4d.BFV_TOP,initw=0, inith=12) self.AddButton(id=b_filename, flags=c4d.BFH_FIT|c4d.BFV_TOP,initw=50, inith=12, name="...") self.GroupEnd() # quality self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT|c4d.BFV_TOP, title="", rows=1, cols=3,) self.AddStaticText(0,flags=c4d.BFH_FIT|c4d.BFV_TOP,initw=90, inith=12,name="Quality") self.AddEditSlider(id=quality, flags=c4d.BFH_SCALEFIT|c4d.BFV_TOP,initw=50, inith=12) self.AddStaticText(id=t_info,flags=c4d.BFH_FIT|c4d.BFV_TOP,initw=120, inith=12, name="--- x ---") self.GroupEnd() self.AddSeparatorH(inith=0, flags=c4d.BFH_FIT) # frames self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT|c4d.BFV_TOP, title="", rows=1, cols=6,) self.AddStaticText(0,flags=c4d.BFH_FIT|c4d.BFV_TOP,initw=90, inith=12,name="From frame") self.AddEditNumberArrows(id=v_start_frame, flags=c4d.BFH_FIT|c4d.BFV_TOP,initw=80, inith=12) self.AddStaticText(0,flags=c4d.BFH_FIT|c4d.BFV_TOP,initw=74, inith=12,name="To frame") self.AddEditNumberArrows(id=v_end_frame, flags=c4d.BFH_FIT|c4d.BFV_TOP,initw=80, inith=12) self.AddButton(id=b_copy_rs, flags=c4d.BFH_SCALEFIT,initw=0, inith=12, name="Copy from Render Settings") self.GroupEnd() self.AddSeparatorH(inith=0, flags=c4d.BFH_FIT) self.GroupBegin(id=0, flags=c4d.BFH_RIGHT, title="", rows=1, cols=2,) self.AddButton(id=b_close, flags=c4d.BFH_RIGHT,initw=60, inith=16, name="Close") self.AddButton(id=b_calculate, flags=c4d.BFH_RIGHT,initw=80, inith=16, name="Calculate") self.GroupEnd() self.GroupEnd() return True # ******************************************************************************* def InitValues(self) : self.SetInt32(id=quality,value=75,min=10,max=100) self.SetInt32(id=v_start_frame,value=0) self.SetInt32(id=v_end_frame,value=99) doc=c4d.documents.GetActiveDocument() rd=doc.GetActiveRenderData() ww=rd[c4d.RDATA_XRES_VIRTUAL] hh=rd[c4d.RDATA_YRES_VIRTUAL] qual=float(self.GetInt32(quality))/100.0 self.SetString(id=t_info,value="( "+str(int(ww*qual))+" x "+str(int(hh*qual))+" )") calculating=False success=False self.Enable(b_abort,False) self.SetTimer(700) return True # ******************************************************************************* def Command(self,id,msg) : global start_frame global end_frame global current_frame global abort global calculating global document_time global start_time global last_estimate global last_estimate_string global frames_dir global masks_dir global main_dir global average_change doc=c4d.documents.GetActiveDocument() if id==quality: rd=doc.GetActiveRenderData() ww=rd[c4d.RDATA_XRES_VIRTUAL] hh=rd[c4d.RDATA_YRES_VIRTUAL] qual=float(self.GetInt32(quality))/100.0 self.SetString(id=t_info,value="( "+str(int(ww*qual))+" x "+str(int(hh*qual))+" )") if id==b_close: self.Close() if id==b_copy_rs: doc=c4d.documents.GetActiveDocument() rd=doc.GetActiveRenderData() start=rd[c4d.RDATA_FRAMEFROM].GetFrame(doc.GetFps()) end=rd[c4d.RDATA_FRAMETO].GetFrame(doc.GetFps()) self.SetInt32(id=v_start_frame,value=start) self.SetInt32(id=v_end_frame,value=end) if id==b_filename: new_filename=c4d.storage.LoadDialog(title="Select the destination folder",flags=c4d.FILESELECT_DIRECTORY) if new_filename!=None: self.SetFilename(id=the_filename,fn=new_filename) if id==b_calculate: # check the path new_filename=self.GetFilename(id=the_filename) if new_filename=="": c4d.gui.MessageDialog("A valid path needs to be set, in order to save the difference masks.") return True if not os.path.exists(new_filename) : c4d.gui.MessageDialog("A valid path needs to be set, in order to save the difference masks.") return True main_dir=new_filename # check start and end frames start_frame=self.GetInt32(id=v_start_frame) end_frame=self.GetInt32(id=v_end_frame) if start_frame>=end_frame: c4d.gui.MessageDialog("There is a problem with the start and/or end frames.") return True # check if the required folders exist. If not, create them frames_dir=os.path.join(new_filename,"frames") if not os.path.exists(frames_dir) : os.mkdir(frames_dir) masks_dir=os.path.join(new_filename,"masks") if not os.path.exists(masks_dir) : os.mkdir(masks_dir) # clip the end_frame, if necessary max_frames=doc.GetMaxTime().GetFrame(doc.GetFps()) if end_frame>max_frames: end_frame=max_frames # disable/enable GUI for calculations self.Enable(b_abort,True) self.Enable(b_calculate,False) self.Enable(b_close,False) self.Enable(b_filename,False) self.Enable(the_filename,False) self.Enable(quality,False) self.Enable(t_info,False) self.Enable(v_start_frame,False) self.Enable(v_end_frame,False) self.Enable(b_copy_rs,False) # adjust all the required variables abort=False calculating=True current_frame=start_frame start_time=time.time() last_estimate=time.strptime("23:59:59","%H:%M:%S") last_estimate_string="" average_change=0 self.counter=1 document_time=doc.GetTime() self.thread.v_quality=float(self.GetInt32(quality))/100.0 # start the calculation self.thread.Start() if id==b_abort: abort=True self.SetString(id=t_info2,value="Aborting...") self.Enable(b_abort,False) self.Enable(b_calculate,True) self.Enable(b_close,True) self.Enable(b_filename,True) self.Enable(the_filename,True) self.Enable(quality,True) self.Enable(t_info,True) self.Enable(v_start_frame,True) self.Enable(v_end_frame,True) self.Enable(b_copy_rs,True) doc.SetTime(document_time) #c4d.EventAdd() return True # ******************************************************************************* def Timer(self, msg) : global start_frame global end_frame global current_frame global abort global calculating global document_time global start_time global last_estimate global last_estimate_string if self.counter==0: if calculating and not abort: spent=time.time()-start_time d=divmod(spent,86400) h=divmod(d[1],3600) m=divmod(h[1],60) s=m[1] time_string="Elapsed: %02d:%02d:%02d" % (h[0],m[0],s) if current_frame>start_frame: each_frame=spent/float(current_frame-start_frame-.1) estimated=(end_frame-current_frame)*each_frame d=divmod(estimated,86400) h=divmod(d[1],3600) m=divmod(h[1],60) s=m[1] last_estimate_string=" ( Estimated time to finish: %02d:%02d:%02d )" % (h[0],m[0],s) last_estimate=estimated time_string=time_string+last_estimate_string self.SetString(id=t_info2,value=time_string) self.counter=(self.counter+1) % 3 if abort==True: self.thread.End(True) calculating=False self.Enable(b_abort,False) self.Enable(b_calculate,True) self.Enable(b_close,True) self.Enable(b_filename,True) self.Enable(the_filename,True) self.Enable(quality,True) self.Enable(t_info,True) self.Enable(v_start_frame,True) self.Enable(v_end_frame,True) self.Enable(b_copy_rs,True) doc=c4d.documents.GetActiveDocument() doc.SetTime(document_time) c4d.StopAllThreads() #Since we can't update the USER_AREA manually while rendering #We must ReDraw it constantly before we start rendering #Only do this ReDrawing when we are actually rendering!!! if self.thread.IsRunning() : self.thumbnail.Redraw() # ******************************************************************************* class BitmapManagerCommandData(c4d.plugins.CommandData) : dialog = None def Execute(self, doc) : """Just create the dialog when the user clicked on the entry in the plugins menu to open it.""" if self.dialog is None: self.dialog = DiffRender() return self.dialog.Open(dlgtype=c4d.DLG_TYPE_MODAL, pluginid=PLUGIN_ID, defaulth=300, defaultw=550) def RestoreLayout(self, sec_ref) : """Same for this method. Just allocate it when the dialog is needed""" if self.dialog is None: self.dialog = DiffRender() return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref) # ******************************************************************************* if __name__ == "__main__": bmp = bitmaps.BaseBitmap() dir, f = os.path.split(__file__) fn = os.path.join(dir, "res", "icon.tif") bmp.InitWith(fn) c4d.plugins.RegisterCommandPlugin(id=PLUGIN_ID, str="Differences Render", help="Renders set of bitmaps with differences between animation frames.",info=0, dat=BitmapManagerCommandData(), icon=bmp)
On 04/02/2016 at 08:48, xxxxxxxx wrote:
That's quite a long piece of code .
First, you're doing forbidden operations in the custom thread: - Modification of the active document (doc.SetTime()) - File operation (open(), write() etc.)
RenderDocument() is called without passing the thread... So it doesn't know it runs from a custom thread. The last (optional) parameter th should be passed self.Get()).
The Main() function of your thread should be used to call RenderDocument() mainly. Modifying the rendered bitmap there should be fine too. All other operations have to be done from the dialog. Modify the document there and run the thread for each frame to render. Then do also the file operation in your dialog after the render and thread have finished each frame.
Also I'm not sure the behavior between globals and a C4DThread is safe. You'd better use members of the custom threads. When the render operation has to be aborted you shouldn't rely on a global bool but immediately end the thread.
On 04/02/2016 at 09:21, xxxxxxxx wrote:
Thank you for the pointers. I will change my code, then. Just one thing... how can I know that a render operation finished for each frame, in order to advance with the bitmap operations?
On 04/02/2016 at 09:24, xxxxxxxx wrote:
Oh, another thing. If I don't set the time of the document inside the thread with doc.SetTime(), simply setting the start/end frame of the render with
will be enough? I mean, will it calculate the animation correctly? Even files with particles and dynamics?
On 05/02/2016 at 01:23, xxxxxxxx wrote:
Originally posted by xxxxxxxx How can I know that a render operation finished for each frame, in order to advance with the bitmap operations?
Use your dialog's Timer() function to keep track of the running thread. When finished do the bitmap and file operations. Then start another thread for the next render if cycle hasn't finished.
Originally posted by xxxxxxxx If I don't set the time of the document inside the thread with doc.SetTime(), simply setting the start/end frame of the render with new_rd[c4d.RDATA_FRAMEFROM]=c4d.BaseTime(current_frame,doc.GetFps()) new_rd[c4d.RDATA_FRAMETO]=c4d.BaseTime(current_frame,doc.GetFps()) will be enough? I mean, will it calculate the animation correctly? Even files with particles and dynamics?
To make sure the document to render is updated for a given frame call ExecutePasses() after SetTime().
On 05/02/2016 at 07:07, xxxxxxxx wrote:
Thank you, Yannick. That sounds logical. My only problem is that my cycle is now in the main thread and it happens in the Command method, while the cycle is running, I have no events for the clicking on the Abort button. How can I create a cycle, when the user clicks "Calculate" and still have a way to cancel the render, by clicking "Abort"?
On 08/02/2016 at 03:47, xxxxxxxx wrote:
Originally posted by xxxxxxxx My only problem is that my cycle is now in the main thread and it happens in the Command method, while the cycle is running, I have no events for the clicking on the Abort button. How can I create a cycle, when the user clicks "Calculate" and still have a way to cancel the render, by clicking "Abort"?
What do you mean by 'cycle'? You shouldn't use a while loop for the render cycle. Use Timer() to check if the thread for the render has finished. If yes do your bitmap and file operations then starts the next render thread.
On 08/02/2016 at 13:22, xxxxxxxx wrote:
Oh, ok. Requires a little more "thinking of" but I will give it a try Another thing... instead of using global variables should I make them all childs of the user thread process? Thank you, Yannick.
On 09/02/2016 at 00:15, xxxxxxxx wrote:
Originally posted by xxxxxxxx Another thing... instead of using global variables should I make them all childs of the user thread process?
It's always better to use member variable in classes. This forces to write cleaner and safer code. Avoid as much as possible using global variables.
