On 19/01/2016 at 11:11, xxxxxxxx wrote:
I'm trying to use FilenameConvertTokens to replace all the tokens in my file path but $pass and $userpass aren't getting replaced.
I'm assuming that I'm not building up my RenderPathData dictionary properly. I'm not clear on what _rBc should be. The docs show that it should be a BaseContainer and the example calls it renderSettings but I'm not sure how to get that information. Currently, I have it set to:
rpData = { '_doc': doc, '_rData': doc.GetActiveRenderData(), '_frame': doc.GetTime().GetFrame(doc.GetFps()) }
I'm also adding a take if it's supported but that's probably not important to this question.
Anyways, hopefully someone can point me in the right direction.
Thanks, Eric
On 20/01/2016 at 01:46, xxxxxxxx wrote:
Hello and welcome,
the Python API is a copy of Cinema's C++ API so you find also a lot useful information in the C++ documentation, also about the Token System.
The RenderPathData dictionary is based on the corresponding object in the C++ API: RenderPathData Struct Reference
So you see the that you could use "_layerTypeName" and "_layerName".
The "_rBc" BaseContainer should contain the render settings. You can get these settings from the document's RenderData:
renderData = doc.GetActiveRenderData() renderSettings = renderData.GetData()
Best wishes, Sebastian
On 29/01/2016 at 10:01, xxxxxxxx wrote:
Hello Eric,
was your question answered?
On 29/01/2016 at 10:03, xxxxxxxx wrote:
Hey Sebastian,
Yeah, I was able to figure it out.
