On 14/01/2016 at 07:25, xxxxxxxx wrote:
I want to flush out the edits of certain parts of a xref character.
How would the code look like, if I want to manually flush the Data of selected objects from a Xref? The flush command is used in the Xref Manager.
Thanks for the info.
On 15/01/2016 at 04:28, xxxxxxxx wrote:
welcome to the Plugin Café forums
I have moved your thread into the SDK Help subform.
Unfortunately this is not possible. The Flush command is hard coded inside the Xref Manager. Sorry.
On 30/08/2016 at 09:08, xxxxxxxx wrote:
Originally posted by xxxxxxxx Hi, welcome to the Plugin Café forums I have moved your thread into the SDK Help subform. Unfortunately this is not possible. The Flush command is hard coded inside the Xref Manager. Sorry.
so that was the truth about flush command? too bad. i thought the issue is just simple but looks like it isn't.
