Boundingbox Size of Point selection
On 21/12/2015 at 02:34, xxxxxxxx wrote:
Hi, I am trying to get the Size of a Pointselection...basically what obj.GetRad() is for Objectsize...but for selected Points.
Is there an easy way?
On 21/12/2015 at 03:28, xxxxxxxx wrote:
The easy way is to calculate it. :) It's simple for a given set of points. Just make sure you use a copy of
the starting point, otherwise you'll have two times the same vector and that will lead to wrong results.
minv = c4d.Vector(points[0])
maxv = c4d.Vector(points[0])
On 21/12/2015 at 03:35, xxxxxxxx wrote:
I tried this...whats not working here?
def GetSelectionSize(op) :
    sel = op.GetPointS()
    points = [(i, point)
          for i, point in enumerate(op.GetAllPoints())
          if sel.IsSelected(i)]
    if not points:
    selsizemin = min(c4d.Vector(point[1]) for point in points)
    selsizemax = max(c4d.Vector(point[1]) for point in points)
    selsize= selsizemax-selsizemin
    return selsize
On 21/12/2015 at 04:10, xxxxxxxx wrote:
You have to find the min/max for each **component (x, y, z)  **of all points, not the min/max of all points.
On 21/12/2015 at 04:11, xxxxxxxx wrote:
Also, why do you write point[1] ? That'll give you the Y component of the Vector.
I guess you are right:joy:
On 21/12/2015 at 04:56, xxxxxxxx wrote:
This Works now. I guess its more complicated than it could be ;-)
    if not points:
    selsizeminX = min(point[1].x for point in points)
    selsizemaxX = max(point[1].x for point in points)
    selsizeminY = min(point[1].y for point in points)
    selsizemaxY = max(point[1].y for point in points)
    selsizeminZ = min(point[1].z for point in points)
    selsizemaxZ = max(point[1].z for point in points)
    boundbox= c4d.Vector(selsizemaxX,selsizemaxY,selsizemaxZ)-c4d.Vector(selsizeminX,selsizeminY,selsizeminZ)
    selsize=boundbox.GetLength()
    return selsize
On 21/12/2015 at 05:00, xxxxxxxx wrote:
Just a question, because Im instrested in: Wouldnt it be better to do all in one for-loop?
On 21/12/2015 at 06:05, xxxxxxxx wrote:
I tried it out. Im not sure if its the best practice, but the results.
from datetime import datetime
class stopwatch() :
  def __init__(self) :
      start = datetime.now()
  def start(self) :
      self.start = datetime.now()
      return self.start
  def stop(self) :
      return datetime.now()-self.start
  points = [(i, point)for i, point in enumerate(op.GetAllPoints())if sel.IsSelected(i)]
  if not points: return
  boundbox = c4d.Vector(selsizemaxX,selsizemaxY,selsizemaxZ)-c4d.Vector(selsizeminX,selsizeminY,selsizeminZ)
  selsize = boundbox.GetLength()
  return selsize
def GetSelectionSize2(obj) :
  v_min = None
  v_max = None
  for i, sel in enumerate(obj.GetPointS().GetAll(obj.GetPointCount())) :
      if sel:
          p = obj.GetPoint(i)
          if v_min == None: v_min = c4d.Vector(p.x, p.y, p.z)
          if v_max == None: v_max = c4d.Vector(p.x, p.y, p.z)
          v_min.x = min(v_min.x, p.x)
          v_min.y = min(v_min.y, p.y)
          v_min.z = min(v_min.z, p.z)
          v_max.x = max(v_max.x, p.x)
          v_max.y = max(v_max.y, p.y)
          v_max.z = max(v_max.z, p.z)
  boundbox = v_max - v_min
  return selsize
def main() :
  obj = op.GetDown()
  t1 = stopwatch()
  t1.start()
  size = GetSelectionSize(obj)
  print t1.stop()
  print size
  t1 = stopwatch()
  t1.start()
  size = GetSelectionSize2(obj)
  print t1.stop()
  print size
  return None
Pointcount 600.001 and 300.000 selected:
GetSelectionSize(obj) : 0.022sec.
GetSelectionSize2(obj) : 0.017sec.
Pointcount 1.500.001 and 750.000 selected:
GetSelectionSize(obj) : 0.469sec.
GetSelectionSize2(obj) : 0.137sec.
