On 12/12/2015 at 08:38, xxxxxxxx wrote:
Is there something like the MCOMMAND_MELT for the Dissolve command? I cant find anything in the documentation. When I use the MCOMMAND_MELT to remove unwanted edges and points it removes all the edges connected to that point.
On 04/01/2016 at 05:35, xxxxxxxx wrote:
"Dissolve" is a Command so it could be used with CallCommand(). The id of that command can be found like any other ID in the " Customize Commands" window. There seems to be no modeling command for "Dissolve".
Best wishes, Sebastian
