On 09/12/2015 at 13:18, xxxxxxxx wrote:
User Information: Cinema 4D Version: 16.011 Platform: Windows ; Language(s) : C++ ;
--------- Hi there,
I'm trying to use BaseDraw::DrawPointArray() to draw shaded points. According to the documentation (https://developers.maxon.net/docs/Cinema4DCPPSDK/html/class_base_draw.html#affe6235c549a43787a1cb5ae5d654d3d) this should be possible by using the aforementioned function. My code looks something like this:
bd->SetLightList(BDRAW_SETLIGHTLIST_SCENELIGHTS); bd->SetPointSize(3.0f); bd->SetMatrix_Matrix(op, bd.GetMg()); bd->DrawPointArray(nPnts, pos, col, 3, norm);
It draws points of the right size in the right position, but no shading is being done (yes, the normals have valid values and are normalized). Does anybody know what I'm doing wrong?
Best Timm
On 11/12/2015 at 07:46, xxxxxxxx wrote:
it seems that DrawPointArray() does not shade the points. We forwarded the question to the developer to get more information.
Best wishes, Sebastian
On 11/12/2015 at 09:43, xxxxxxxx wrote:
It works fine for me in R13. Add this code to the SDK AtomObject example and see if it works in your version.
class AtomObject : public ObjectData { public: DRAWRESULT Draw(BaseObject *op, DRAWPASS drawpass, BaseDraw *bd, BaseDrawHelp *bh); virtual Bool Init(GeListNode *node); virtual BaseObject* GetVirtualObjects(BaseObject *op, HierarchyHelp *hh); virtual Bool Message(GeListNode *node, LONG type, void *t_data); static NodeData *Alloc(void) { return gNew AtomObject; } }; DRAWRESULT AtomObject::Draw(BaseObject *op, DRAWPASS drawpass, BaseDraw *bd, BaseDrawHelp *bh) { bd->SetMatrix_Screen(); bd->SetPointSize(5.5); LONG count = 3; SVector pointpos[3] = { SVector(500, 200, 0), SVector(510, 200, 0), SVector(520, 200, 0) }; //Create the array with the point positions SVector normals[3] = { SVector(1, 0, 0), SVector(1, 0, 0), SVector(1, 0, 0) }; //The normals directions SReal pointcolors[9] = { 1, 0, 0, 0, 1, 0, 0, 0, 0 }; //Each point needs 3 color values(RGB) bd->DrawPointArray(count, pointpos, pointcolors, 3, normals); //Draws the points on the screen return DRAWRESULT_OK; }
On 15/12/2015 at 05:49, xxxxxxxx wrote:
Hi Scott,
thanks for your example. Doesn't do anything to convince me, though. The normals all point in the same direction (and a weird one) and are all flat colored. Changing the POV, the light in the scene or the default light doesn't change anything in the color of the points.
Does this really work for you? Can you send a screenshot?
@Sebastian: Thanks for looking into it!
On 15/12/2015 at 07:22, xxxxxxxx wrote:
Hi Timm,
We got confirmation that BaseDraw::DrawPointArray() doesn't shade the points. The normals that can be passed are reserved for later use.
On 15/12/2015 at 07:27, xxxxxxxx wrote:
Hi Yannick,
Originally posted by xxxxxxxx We got confirmation that BaseDraw::DrawPointArray() doesn't shade the points. The normals that can be passed are reserved for later use.
ok, thanks for the quick confirmation! It might be sensible to mention that in the documentation. But what I'd like to know more: Are there any plans to make this functional soon? That'd allow for some pretty slick editor drawing tricks. ;-)
On 15/12/2015 at 07:54, xxxxxxxx wrote:
Originally posted by xxxxxxxx Hi Scott, Does this really work for you? Can you send a screenshot?
My bad. When you said "shade". I thought you were talking about the "color" of them.
