On 05/12/2015 at 21:44, xxxxxxxx wrote:
I have a simple polygon and the MCOMMAND_SUBDIVIDE ** ** divides it in 4.
Now my question:
Is there a way that I can divide it in only 2 instead of 4??
Thanks
On 06/12/2015 at 02:11, xxxxxxxx wrote:
You mean asymmetrically? No, that is topologically not possible.
Imagine the three squares that meet in a corner of a cube. Try subdividing them in only one direction (in any possible combination - there are eight cases, many of which are topologically symmetric). You will see that it is not possible to cut them in a way that will not ALSO generate an additional point on an edge of a poly that has already been cut.
On 07/12/2015 at 01:53, xxxxxxxx wrote:
the MCOMMAND_SUBDIVIDE simply applies a subdivision algorithm that creates for polygons for each given quad.
Best wishes, Sebastian
