How to load Rendersettings from an external file?
On 29/11/2015 at 09:17, xxxxxxxx wrote:
Hey there,
so I got around the Idea to insert rendersettings from an external file, wich is located in the res folder of my plugin.
I tried it with Mergedocument but this doesn't merge the rendersettings.
I also tried some other things, but no one worked
And I don't want it to load a new file either.So is there a way?
greetings,
neon
On 30/11/2015 at 01:37, xxxxxxxx wrote:
could you explain what exactly do you mean with "from an external file"? Do you mean another *.c4d file?
Then you could use LoadDocument() to load that file to memory and read its render settings with GetActiveRenderData(). With that settings you can synchronize the settings of the target document.
Best wishes,
Sebastian
On 04/12/2015 at 08:08, xxxxxxxx wrote:
What about creating a new render setting via Python and setting the parameters you want in the script?
Here is a sample of one I created as part of another script. newDoc at the end is the new document I had created that I was inserting the render settings into. You might use doc instead if the current document you are inserting the render settings into.
def renderSettings() : dNewRD = documents.RenderData() # create new render setting dNewRD.SetName("Render Library Preview") sketch = c4d.BaseList2D(1011015) #object id found by GetType() dNewRD.InsertVideoPostLast(sketch)# add S&T to render setting dNewRD[c4d.RDATA_FORMAT] = c4d.FILTER_JPG dNewRD[c4d.RDATA_ANTIALIASING] = c4d.RDATA_ANTIALIASING_BEST dNewRD[c4d.RDATA_AAMAXLEVEL] = c4d.RDATA_AAMAXLEVEL_2 dNewRD[c4d.RDATA_AATHRESHOLD] = .04 dNewRD[c4d.RDATA_PATH] = targetPath + "/" + objName + ".c4d" newDoc.InsertRenderData(dNewRD) # insert new render setting into document newDoc.SetActiveRenderData(dNewRD) #set new setting as the active render setting
On 11/12/2015 at 08:30, xxxxxxxx wrote:
Hello Neon,
was your question answered?
Best wishes,
Sebastian
