On 16/11/2015 at 13:04, xxxxxxxx wrote:
Trying to set a Mat settings to open a image file from res? It dont do that, it Just generate material with the settings but not the Texture Setting to the Imagine file. What I am doing wrong? PlZ Help GUYS!
----------------------------------------------------------------------------------------------------------------------- CODE: def Execute(self, doc) : #--| Generate MAT |--# Tex2K = c4d.BaseMaterial(5703) Tex2K[c4d.ID_BASELIST_NAME] = "2K Checker Tex" doc.InsertMaterial(Tex2K)
#--| OPEN THIS IMAGE from the Res Folder |--# filename_TEXpath = os.path.join(os.path.dirname(__file__), "res/CB_Textures", "UV Checkers Box -[2K Tex].png")
#--| SET MATERIAL SETTINGS |--# Tex2K[c4d.MATERIAL_PREVIEWSIZE]=11 Tex2K[c4d.MATERIAL_USE_REFLECTION]=False 49 Tex2K[c4d.BITMAPSHADER_FILENAME]=filename_TEXpath
c4d.EventAdd() return True ------------------------------------------------------------------------------------------------------------------------- Console Say: Traceback (most recent call last) : File "'2K Checkers Texture.pyp'", line 49, in Execute TypeError: __setitem__ expected int or bool, not str -------------------------------------------------------------------------------------------------------------------------
Plz Help or Tips, Ashton
On 17/11/2015 at 03:54, xxxxxxxx wrote:
Hi Ashton,
a standard Material has no parameter BITMAPSHADER_FILENAME, that's why your script fails. Instead you need to allocate a Bitmap Shader, set the parameter there and then insert the shader into the material. An example can be seen on InsertShader().
In your case it could look like so:
#--| Generate MAT |--# Tex2K = c4d.BaseMaterial(5703) Tex2K[c4d.ID_BASELIST_NAME] = "2K Checker Tex" #--| OPEN THIS IMAGE from the Res Folder |--# filename_TEXpath = os.path.join(os.path.dirname(__file__), "res", "CB_Textures", "UV Checkers Box -[2K Tex].png") shdBitmap = c4d.BaseShader(c4d.Xbitmap) if shdBitmap is None: print "Error: Shader allocation failed" return shdBitmap[c4d.BITMAPSHADER_FILENAME] = filename_TEXpath #--| SET MATERIAL SETTINGS |--# Tex2K[c4d.MATERIAL_PREVIEWSIZE] = 11 Tex2K[c4d.MATERIAL_USE_REFLECTION] = False Tex2K[c4d.MATERIAL_COLOR_SHADER] = shdBitmap Tex2K.InsertShader(shdBitmap) doc.InsertMaterial(Tex2K) c4d.EventAdd() return
On 17/11/2015 at 06:09, xxxxxxxx wrote:
Thanks Andreas it works! , really thanks man , your a hero! Cheers, Ashton
